Valve Deposits
Valve Deposits
A few months ago I noticed too much carbon depsosits on the back of the intake valves and straightway began using intake cleaner of some sort mixed with each fillup. Looked at them again the other day and see no improvement at all. I won't be using that product again and so am seeking advice on something else that is reputed to work. What do you use and why?
Try a product called seafoam. I've used it and it seems to work pretty good. When you use it, don't be alarmed at the amount of smoke that will come pouring out of the tail pipes. Then you might want to start using a fuel additive from time to time.
