Tuning Issues+ riding style+ dyno + frustration !!
Old 09-03-2008 | 08:47 AM
vasaq's Avatar
Test
vasaq is on a distinguished road
when I got my hawk I had some carb issues ....there would be fire from the tubes and i smelt gas all the time ....my bike would start sputtering around 90-110mph.
1) i had my carbs rejetted (+ new plugs) and it seemed to fix the problem for a while
2) the problem came back ...i was convinced that the plugs fouled up and was asked to get new ones. I did . seemed to fix it for a while
But I am not happy with it now as well...when I ride the twisties i run into a sputtering once in a while..
I dont know if my riding style is bad ....maybe I shouldnt go to first gear in tight turns? Is there any particular riding I should be doing on my vtwin ..
Secondly, should I consider getting the hawk on a dyno and getting it rejetted?
Thirdly, is this issue common...I really want my hawk tuned very well?
Finally, given that I dont have a garage can I learn how to tune my bike myself? if Yes, can someone point me to the 'dummys guide to tuning a Superhawk' or something along those lines.
Please let me know if you can. ( I am not familiar with all bike terms so please break it down for a me a bit if it is too technical?)
Cheers
Vasaq
Old 09-03-2008 | 09:35 AM
Jim TT's Avatar
Jim TT
It is hard to help not knowing what you jetting and carb settings are. JIM
Old 09-03-2008 | 09:46 AM
filter69's Avatar
Thats Mr Dill hole to you
Also stock exhaust or after market what air filter any timing changes etc ...
all need to to taken into account also what type of jet kit (if any ) if your running like say a 180/185 dyno jet with stock exhaust your to damn rich
after market slipons good air filter etc i have had good luck with 178/180 with a flo commander installed for final tuneing but YMMV....
Old 09-03-2008 | 04:19 PM
gboezio's Avatar
Take a clear pic of the plugs end and post it, this should get you the best advice
Old 09-03-2008 | 04:40 PM
Also 1st gear, but at what speeds or more importantly what RPM's?
No reason to wring a SH to high RPM's, peak power is ~6k not up at redline.
Old 09-04-2008 | 08:58 AM
vasaq's Avatar
Test
Ok ..I dont know how to answer these questions but I will go to the mechanic with a print out of these questions and ask them.
Are there any other questions to be asked?
Please let me know and I will find out.
Cheers
Vasaq
Old 09-04-2008 | 09:07 AM
vasaq's Avatar
Test
I will wait one more day before I go to the mechanic shop
Old 09-04-2008 | 10:12 AM
rbrais's Avatar
A good mechanic should be able to tune your bike correctly. As a novice mechanic, it could take a lot of trial and error on your part to figure it out. If you are going to the shop to ask those questions, let him take a look at her.
Old 09-04-2008 | 03:17 PM
vasaq's Avatar
Test
well i have already spent 400$ having him tune it ...he assured me that the tuning was good and i had no way of knowing if his tuning was correct...it seemed ok and at times it fails
i am not going to mess with anything ...
cheers
Old 01-23-2011 | 08:35 PM
vasaq's Avatar
Test
test
99superchicken
12-12-2018 06:21 PM
E.Marquez
03-15-2012 09:19 PM
Stevebis1
09-28-2010 11:39 PM
thefitzvh
01-13-2010 07:51 PM
iamanonymous
09-05-2006 01:56 PM
