Stock front brake line length?
Old 11-22-2013 | 10:05 PM
What is the stock front brake line length? Believe me I searched and could not find any post with the exact length for the stock brake lines.
I found some Goodridge steel brake lines that came off a SV650 for $30. The guy is going to measure the lines for me this Sunday to see if they will fit the Superhawk. I'm hoping they will fit and maybe have a little slack in 'em, just in case I go with different bars.
Old 11-22-2013 | 10:11 PM
KCCO's Avatar
Are you looking for the straight line length or including the length with the splitter block?
Old 11-22-2013 | 10:15 PM
Don't most aftermarket companies do without the splitter and just run two lines off the master? Just looking for the length from the master cylinder to the caliper. I would check my bike, but can't for several days right now.
Old 11-22-2013 | 10:28 PM
KCCO's Avatar
Give me a few minutes and I'll run out to the garage.... brb
Old 11-22-2013 | 10:33 PM
KCCO's Avatar
With the bike sitting on the ground, with superbike bars, you are looking at 24" from bolt to bolt with a little play room, does this help?
Old 11-22-2013 | 10:38 PM
Yes it does. It is exactly the information I was looking for. You rock man, thank you!
Old 11-22-2013 | 10:41 PM
Almost forgot, which caliper did you measure to? The furthest away from the master cylinder?
KCCO's Avatar
No problem, I would guess anything over 26" should be ok, and obviously longer is ok as long as its not ape hanger longer
killer5280
01-15-2010 05:34 AM
roisman
03-25-2008 11:43 AM
spdrcr
10-26-2007 08:35 AM
cliby
03-08-2007 07:13 AM
CNI Dawg
11-06-2005 07:59 PM
