Seat Lock/Latch Not Working - What Now?
Old 07-31-2011 | 02:54 PM
JamieDaugherty's Avatar
I had this happen once before but somehow managed to get it apart without much fuss. This time I'm not so lucky. Something is up with my seat lock and it's not pulling the latch cable. I think the cable itself it disconnected. Honda did a really good job of designing the seat so that you can't get in there easily to steal stuff under the seat. That neat feature is causing my some greif now.
Anyone else have this happen to them? I'm looking for a good solution before getting violent with it.
Old 07-31-2011 | 03:55 PM
tomzxt's Avatar
Light Cycle Expert
If you have the stock undertail you might be able to get in there by removing the two plastic pop screws at the rear. It should give you enough room to at least get a hook in there to pull the cable.
Old 07-31-2011 | 04:49 PM
The stock rear fender extends all of the way forward to the battery. There is no way (that I know of) to remove it without already having the seat off. If it's possible let me know!
Old 07-31-2011 | 06:24 PM
Thumper's Avatar
You sure it is the cable and just not a stubborn seat position. I had a heck time getting my seat off when i bought my bike. Someone posted up on the original SuperHawk site (RLZ) years ago that once you got the seat off to take a hammer and slightly knock the metal latch loops forward maybe an 1/8" to allow seat to go on and off better.
Sorry not much help with how to get yours off.
Old 07-31-2011 | 06:27 PM
Also try pushing down on the seat when you try to turn the key
Old 07-31-2011 | 06:51 PM
superhen's Avatar
First, take off the seat cowl (if you have one on). I think what Tomzxt was saying, is you can loosen up the rear cowl by taking out the 2 black pop screws. So you won't be able to take off the whole tail cowl, but you can raise it up a little (too far and you'd break the front tabs which bolt to the subbie). Then you should be able to see under the seat and hook it with a hangar. Might require you to have a helper or briefly morph into an octopus.
Old 07-31-2011 | 07:34 PM
Yeah, I'm almost positive it's the cable. I take my seat off quite often (that's why it's a big deal). I've tried and tried all of the typical things, the key is just moving the catch. I've already modified my hooks to make the off-and-on easier.
I can't get to my rear two screws because the seat is in the way. Looks like I'm going to have to figure out a way though as that's also been the only option I can see. Was kind of hoping someone has been through this before and knew a trick.
Old 07-31-2011 | 07:55 PM
zmaniv's Avatar
Ball drive Allen wrench works great
Old 07-31-2011 | 09:05 PM
Ha ha, they are Phillips head screws!
Old 07-31-2011 | 09:21 PM
Refer to the "Post Whoring Newbie Thread".
Just kidding. I've had to use alternative methods to get car hoods open when the cable is broken. I'll go check my bike and see if there's any way to get in there with a long screwdriver or something.
Old 07-31-2011 | 09:45 PM
There's a depression in the undertail where the original tool kit goes (it starts about 3 1/2" forward from the rear of the flat part of the tail section, looking from underneath). To the left of it is a narrower depression, rounded and about 1" wide. Looking from underneath, if you drill a hole at the rear of the narrower depression, you should be able to get a narrow blade screwdriver up to trip the catch. Push it to the left.
Good luck.
Old 07-31-2011 | 11:07 PM
tomzxt's Avatar
Light Cycle Expert
Don't drill any holes. Give me five minutes and I'll post a video that will get your seat off in 30 seconds.
Old 07-31-2011 | 11:37 PM
tomzxt's Avatar
Light Cycle Expert
Just made this video for you. Same thing as I wrote to do above. Only thing I didn't mention in the video is once you have the seat off check to make sure the white plastic part of the cable is in its spot to keep the slack out of the cable so it works properly. It's the first spot I point to on the video.
‪Honda Superhawk seat removal‬‏ - YouTube
Old 08-01-2011 | 12:17 AM
Very good... that works.
Old 08-01-2011 | 04:06 AM
nekkid's Avatar
Oh great...posted on You Tube...
I hope this doesn't spark a crime wave...
Old 08-03-2011 | 09:27 AM
superhen's Avatar
So, Jamie, did you get that seat off?
Old 08-03-2011 | 07:50 PM
Not yet. My rear tailsection fairing has some extra "reinforcements" that I will have to deal with. I think tomzxt's method will do the trick though.
Old 08-05-2011 | 11:25 PM
ProfChaos's Avatar
ProfChaos is on a distinguished road
If you have a tool kit or some power bars or something under the seat, they might have slid forward against the two seat hooks, making it feel as if your release cable is not working, because the hooks won't release properly. Or, something might be wedged under the latch release, again making it seem as if the cable is not working. As someone else said, try pushing the seat down/try pulling the seat up while you wriggle the key back-and-forth, or maybe do something--but not too drastic--to get the under-seat cargo to shift in a good way.
After you get the seat off, there are one or two plastic tabs somewhere under the seat pan that I vaguely remember having cut off with diagonal cutters to prevent this sort of thing from happening so easily. ....I believe that there was a thread on the old SuperHawk Forum illustrating the seat pan plastic-tab-ectomy.
cheers,
--Professor Chaos
Old 08-11-2011 | 05:59 PM
The problem is that the cable sheath is slipping out of the holder where it connects with the latch. I know that from previous experiences with this bike.
I've been so busy lately that I really haven't had any time to mess with it. Once I get back in town I'll try some more and hopefully get some success.
Old 08-15-2011 | 04:32 AM
Garbanzo's Avatar
Garbanzo is on a distinguished road
With your hand use a slight upward force on the rear or the seat, then karate chop the lower section - where the seat rises rearward. works for me....
curlcd
10-07-2014 03:04 PM
Cyfac0183
09-06-2011 10:10 AM
smokinjoe73
11-05-2010 10:44 PM
superman_006
06-30-2009 06:46 AM
Caine72
07-29-2007 04:09 PM
