Rc 51 runs in reverse google vid
Old 01-24-2008 | 01:12 PM
SuperPelikan's Avatar
SuperPelikan is on a distinguished road
http://video.google.com/videoplay?do...86677978894957
wtf hows that happen!
Old 01-24-2008 | 01:25 PM
superbling's Avatar
I'm going to say he's somehow manage to start the motor backwards. I've never seen it or experienced it myself but I hear it was quite common on the old two strokes and their questionable electrics of the day.
It happens during the startup. The spark ignites too early and the piston/crank doesn't have enough built up inertia yet to continue past TDC thus it is forced back down the opposite (wrong) way. Since everything is tied together via chains or gears, the motor doesn't really care and runs just fine. And if the rider doesn't know, once they pop it into gear and let out the clutch...... yipppeeeee!!!!!
I'm scratching my head on how you could get an RC(4stroke) to do it tho. (?)
Old 01-24-2008 | 01:56 PM
Lefin102's Avatar
neat! but the oil pump runs in one direction and backwards aint it!
Old 01-24-2008 | 02:11 PM
I'd be more inclined to think it is a transmission problem
Old 01-24-2008 | 02:13 PM
FL02SupaHawk996's Avatar
Fastest Color
hope he's using M1 20W-50
Old 01-24-2008 | 02:14 PM
I'm scratching my head on how you could get an RC to do it tho. (?)
By reversing the polarities on the starter...?
Obvious ly somebody is exceptional at working on thier RC51....
Old 01-24-2008 | 02:16 PM
possible answers
http://www.rcuniverse.com/forum/m_44...tm.htm#4430470
http://answers.yahoo.com/question/in...1185445AAkmP4V
I think the 2nd hypothesis is close; overly advanced ignition timing and keeping the revs low once started in reverse.
It really doesn't sound like he's going through the gears until he gets to 6th and it stalls... the rest of the take off's sound almost identical.
Old 01-24-2008 | 02:45 PM
Yup, also if in reverse, the "exhaust" would be getting blown out the airbox and sucking air in the exhaust, and that'd sound very different.
Old 01-24-2008 | 02:53 PM
fuzzuki's Avatar
fuzzuki is on a distinguished road
I'de say the engine is running forward, but the transmission isn't assembled correctly.
Or the back wheel is mounted backwards.
Old 01-24-2008 | 03:03 PM
seaton001's Avatar
seaton001 is on a distinguished road
autoteach's Avatar
You can not start a four stroke in reverse. You can do this with a two stroke, though. It is impossible because the fuel would never make it in the cylinder as it is injected before the intake valve (in reverse, after). On a two stroke, the operation is the same, the ignition advance is not.
Old 01-24-2008 | 03:12 PM
434josh's Avatar
434josh is on a distinguished road
with a very slight timing change, you can run a 2 stroke backwards all day long. but not a 4 stroke. the cams timing would have to be seriously modified which is easier to do than the transmission. I bet they simply switched the cams and degreed them correct to the ignition timing.
edit...they would also have to switch the plug wires. but the whole thing wouldn't take that long.
Old 01-24-2008 | 03:44 PM
it's not a 2 stroke, it's a 4 stroke
Old 01-24-2008 | 04:25 PM
434josh's Avatar
ya think???
didn't say it was.
Old 01-24-2008 | 07:03 PM
fuzzuki's Avatar
It's a two stroke X2= 4 stroke
Old 01-24-2008 | 07:46 PM
434josh's Avatar
since it is a 4 stroke and 2 cylinders in a V and 90deg, you could put front cyl cams on rear and vice versa, time them exactly backwards, switch the plug wires and reverse starter polarity. boom, motor turns backwards and will fire properly pulling air/fuel thru the intake and pushing exhaust out all proper like.
Thats my theory at least......
Old 01-25-2008 | 09:39 AM
RCVTR's Avatar
There are no stupid questions.
Only stupid people.
Old 01-25-2008 | 09:56 AM
Steve30v's Avatar
Steve30v is on a distinguished road
I think he put the key in backwards.
Old 01-25-2008 | 10:19 AM
Hotbrakes's Avatar
Sounds like a gear got switched in the tranny.
A few months ago I was able to get my firetruck at work to run in reverse. Its a Detroit Diesel 8V-92 2 stroke. It has a button that you push and hold to turn it off. I went to turn it off and released the button a split second early I guess so the engine was still cranking over. It fired back up when I let go and started smoking out of the intake. So me, thinking it got too much fuel floored it to try to clear it out kinda like a 2 stroke gas motor that loads up. It just blew out more smoke from the intake so I decided to take it down the road. I got about 500 feet away from the station and the little power it was making quickly dwindled to nothing. We called a tow truck and got it back to the station and the mechanic said it ran backwards. Unfortunately the fuel pump is gear driven off the engine so it ran backwards as well pushing all the fuel out of the line and when it ran dry it shut down. The mechanic reprimed the fuel line and it ran fine after that.
Old 01-25-2008 | 10:15 PM
Thumper's Avatar
Owners Explanation:
The owner claimed he took the bike in for service at the dealer and when he got it back the motor ran backward.
Actually the motor was running correctly. The dealer's "mechanics" had routed the chain around the swing arm piviot bolt just behind the countershaft sprocket. There was just enough room for the rear of the sprocket to catch the chain as it was turning the correct direction, but pull the chain in reverse. Here is what the owner posted later...
The bike has been fixed What happened was when they put the chain (530)on the bike it must have draped in between the swingarm pivot bolt and the countershaft sprocket.And there fore the chain was being rotated from the top making it go backwards. If I had taken the time to do the nickey mod I would have noticed it right away. The guys at the shop (procycles) say the 530 chain fits perfect inbetween the counter shaft and swing arm pivot bolt. So if you thought this was a hoax I would say try this to your own bike and see if it goes backwards. All I know is my bike is now fixed and now it needs to stop raining so I can ride the bitch.
Old 01-26-2008 | 07:21 AM
fuzzuki's Avatar
Sounds like a top notch shop.
Maybe I should bring my bike in for a big bore kit, and a race cam.
Old 01-27-2008 | 06:04 AM
yeah sounds like a good repair shop, ride your bike in back it out!
00SUPERHAWK
12-08-2013 08:33 AM
rz_racer_69
02-14-2012 07:36 PM
Thumper
10-30-2011 11:52 PM
vitter
02-28-2006 05:13 PM
Anonymous
SuperHawkForum Mailing List
07-06-2005 11:36 PM
