question......
question......
I am new to the superhawk / sportbike world.
Want to learn to wheelie my bike , but I do not wish to drop it.
Saw on e-bay a vidio on wheelies on a vtr.
Has anyone seen this ?
I am sure many of the vet's , are rolling laughing at this squidish request, however , money is tight in this household so........
Any serious information is very much appriciated , and I humble myself to the jokesters that want to chime in.
Thanks
L-man out??:
Thanks
L-man out??:
Wheelie
Check out this site and see if it helps. Maybe get some input from some of you vets out there.
http://bikerpunks.com/page/35/
Wheelies with a Superhawk are pretty easy. You should be able to hoist it up with only a little effort.
From a dead stop - Revs up, clutch out. Bring up the revs a little more each time.
While in motion (1st or 2nd gear) - Roll off throttle, pull clutch in, gas up, clutch out. You may need to "bounce" the handlebars to get a little more lift.
With very little practice, I was bringing up 1-foot wheelies. Not very exciting stuff, but I feel safer with two wheels on the ground.
I don't know if this is an option for you or not but if you want to learn how to wheelie find a dirt bike! The only way to learn is practice and the only way to practice is to do it and probably fall a few times.??: Just my opinion but pavement hurts!!
In the fall and spring when the air is clean and cool i can get mine to pull a third gear wheelie with a little clutch slip running arounf 5.5-6 k rpm, but in the summer she aint going solo in third unless you shift into third while on a 2nd gear wheelie.
For me 2nd gear is the best gear to wheelie in, just a slight slip of the clutch running around 5k and the front is skyward.
A good suggestion is if you plan to do a lot of these i would upgrade the shitty ball type bearings in the triple tree with some goos aftermarker roller bearings.
hummmm I don't ever recall having to roll off and back on hard to get the SuperChicked to go solo.
bpw
11-26-2013 10:16 AM
