POLL - Front & Rear Shock Setting
about to adjust fronts and the shock in the back (the yellow one under my behind ) . was curious as to where you guys have your fron and rear settings at .
please state hieght/weight and how many turns out or in in front and notch setting for rear(1-7?) , notch 1 being the lowest notch(lowered the most) . also, please ad any mods you have done to the suspension (shims, etc) .
thanks
thanks
5' 8" & 180lbs
I'm still experimenting with the settings on my fully stock suspension.
For around town riding I usually run the front preload @ 3 rings, and rebound @ 1 turn from full hard; and the back preload at the 3rd position, with rebound @ 1 turn from full hard. On weekends I the same preload, but just do a half turn on front & rear rebound.
Re: POLL - Front & Rear Shock Setting
ok, im gonna adjust mine. im 5'9 160 lbs, and am thinkin the 2nd would be a good notch for me but dont know anything about the front prel. and compr.
i do city drivin, and occassional twisties, but mostly crappy roads and bums and stuff common to Ohio's fine roadways
Originally Posted by marmaladeboy
I dunno if this helps, but I had Race Tech front springs (1.0kg/mm) in the forks and the rear shock was at 5 clicks.
I had planned on shimming the rear shock, but never got around to it.
Anto
08-27-2012 03:57 PM
