Pazzo Levers
Moderatio est Figmentum
Pazzo Levers
Looking for opinions. I am seriously contemplating a set of shorties. I generally only use two fingers anyway. Are they worth it? Does anyone else have them and what are your opinions. www.solomotoparts.com has them for $179.99 a set.
Thanks in advance.
Thanks in advance.
No kidding on the price, if I wasn't working so much overtime at the time I woudn't have bought them. Definitely glad I did though, I got the shorties and they seem more comfortable than stock, since I only use 1 or 2 fingers anyway (insert innuendo here).
The hardest decision was which color combo to get..
I'd rather do a trackday and have an extra set of $20 levers laying around for a rainy day personally. But if money is no object they are definitely a trick piece of oogle to add with unbreakability to boot.
Well it looks like motomummy has them for the same price but they will throw in a $17 set of grips. I may have to go ahead and order them. I like the ASV's but not for $225.
I found a cool trick when I was doing my clutch lever.
That dam rod came out of the rubber boot in the clutch MC. So after I fought with getting it back on for a minute I decided to try another way.
I placed 2 of the 4inch zip ties with the heads up inside the accordian/boot.
Both of the zip ties were opposite of each other with the insertion side facing each other. I pushed the rod into the boot and pulled back on the ends of the zip ties and the accordian popped back onto the groove on the rod where it belongs.
I bought a set of Powerstands Click-n-roll shorties and love them. I had to shim the clutch side ever so slightly to remove a bit of play but all is well. Feel is much better. Though not essential, they are a nice add-on.
I suggest you shop around on eBay, deals are bound to show up.
jonnykuhns
01-07-2007 10:38 AM
