Over heating 996
Over heating 996
Hello to all. I just joined the forum. I have a 1999 Superhawk and seems when I do some good distance ridding my bike wants to overheat. I have checked the pump and know that it is connected to the motor and it works fine when the bike is on. Fans working fine. Flushed it and put in new coolant. But seems that no matter what it goes past the half way point on the guage and to the touch it seems to me to be hot. One time last season it got so hot it released to the overflow tank. No coolant in the oil or anything like that. Only thing I have not checked is the cap!! Can a pressure cap be bad if it does not leak? from the cap? And it is not over flowing to the overflow unless it gets to hot... Any help would be greatly appreciated...I just want to ride free and not worry about it...
radiator cap cross reference
An alternate to oem is Stant #10233 available at Advance Auto for 7.49. 1.1 bar=16lb. I found my gasket was split on the original cap while I was changing coolant. I also found my overflow bottle was plugged. I unhooked the overflow hose to drain the bottle and nothing came out. I used my compressor to clear the blockage while flushing the bottle with a hose and let the sediment float out.Just wanted to share this because the overflow function probably rarely gets tested
Thanks guys I will check the overflow and replace the cap. The ambient temp is to be determined have not rode her yet this year.. Going through the whole bike this year, brakes and so on. I appreciate all the feedback. Thanx
The recovery bottle should always have coolant rise up in it when the engine is hot. As the coolant gets hot it expands and pushes coolant to the bottle. If it's not pushing coolant into the bottle you are low on coolant. It should always have coolant up to the full lines and should go up and down as the engine gets hot and cools off.
