NGK dual electrode plugs
2: Then you would not get much if any CR increase. It's not a problem unless you run your bikes way rich, and or, do not remove your plugs but once a year. This is a simple mod, for those that work on bikes for fun, and or are trying to get every possible HP from a motor.
Same answer as mine above. It's not a "new" thing,, He was just the first to write it up and set it to a web page. It works very well. Proven by hundreds of motors, both high end race motors and OEM street motors. I've used it on dozens of motors myself, from start to finish, including tear down months or years later. It works. But as this is the internet.. there will now come on 10 people who are going to quote the owners manual, tell us about the OEM engineers are all knowing as opposed to some guy on the internet, ect ect ect. Thats ok.... It's there motor. I've been inside a lot of those "OEM manual" broken in motors........ I'll stick with what works.
Back to the plugs, agree with the possible sealing problem with two washers.
My other thought is that this mod will work better in 4 cyl engines than twins, and also smaller capacity engines. The smaller the combustion chamber the larger the effect the plug will have, as it will be a greater percentage decrease in chamber size. So maybe on our bikes with their two large cylinders it may amount to "not much"!
I came across this topic on a snowmobile forum where someone stated that a well-known Yamaha racer was claiming 2-3 additional hp (in addition to greatly improved throttle response) on a Yamaha Apex snowmobile (essentially a 2002-2003 converted R1 engine).
So I guess that means, considering our larger cylinders and lower redline, that we'd make maybe and extra 1/2 to 1 HP...??
Heh, I'm just making a reasonably educated guess, based on the Yamaha racer's claim.
Hey.. seat-of-the-pants dyno is where it's at. Someone should throw them in the SHawk and tell us what they think! heheheh
justinity
10-10-2010 11:45 AM
