New tire feedback/ review Bridgestones
Old 02-24-2012 | 07:49 AM
jeephawk's Avatar
jeephawk is on a distinguished road
Just thought to post here since this tire is new and some might run it on their SH.....
I bought my bike with Bridgestone Battlax bt016 on it. This is my first liter bike. I haven't done any track time but I am pretty close to getting my chicken strip touched. That basically shows my experience level. (novice)
Anyways the 016s seemed like a good tire. I rode last spring until just recently on them before they went out. I got about 6000 on both and rear tires. Grip seemed fine. Never had it slide out. The rear center wore pretty quickly for a commuter tire in the middle. It seemed to wear out faster after a very hot long straight trip on time. After that the rear went quickly.
Anyways I researched tires. I wanted to ride through the winter and on into this year. I wanted a good all around tire that would handle wet roads, still have grip for corners and had a harder center patch for commutes.....
I ended up getting the Bridgestone BT023GT. The GT is for heavier bikes like ours. Basically has harder center material for heavier bikes.
I ended up running the rear first and ran the 016 in the front for a bit.
The rear seems to be the same as the rear 016 so far. Ive put over a 1000 on it so far and wear is fine. Grip is fine. Wet weather is fine.
I just got the front and immediately i noticed that it changed how the Superhawk steers.... I mean by that it felt heavy in the front vs the used 016. Now I wore the sides pretty bad on the front to where it had a very pronounced arc to it. I think that has a lot to do with it. The front does feel really reliable though, if that makes any sense. It just is taking some time to get used to. I cant flick it into the corner as quickly as before. Now its more of a controlled preloaded feel if that make sense. But it seems to grip fine. It has alot of channels in the front tire so wet weather should be no problem. These tires have a softer sides to them too for dry cornering. Dual compound tire.
My opinion of these tire is that I would recommend this tire to commuters or riders of superhawks that want a good all around tire that doesn't wear out quickly. Ive read of people getting 10k on these. I picked up the rear for 120.00 and the front for 111.00
Anyways not trying to sound like a Bridgestone commercial or anything. Just want to put it out for Superhawk owners. You might want to check them out if you like Battlaxes.
Old 02-24-2012 | 08:42 AM
superhawk22's Avatar
The change in the feel you notice is because of the shape of th tire, the 016 is a more agressive tire on the boarder of a track day tire. The 023 is a true commuting tire, the difference is the 016 is made to corner so it has a more triangular shape, while the 023 is a true commuting tire so it focuses more on straight line stability. Both are good tires but have different attributes.
Old 02-24-2012 | 08:46 AM
Oh and you can adjust suspension to get that flickability back by shiming the rear shock or raising the forks in the tripled.
Old 02-24-2012 | 09:46 AM
I get 10k from my front and about 8k rear on my Metzeler Z6's. I don't have any grip issues with them either. I guess once you get comfortable w/ a certain brand you tend to stick w/ it. I had Z4's on my old Hawk GT and like the grip/mileage. When I bought the VTR it had Conti's and about 4k the rear was toast. I just can't afford to put rubber on it that frequently. I actually thought about getting a stickier front this time but found a NOS (now they're Z8) front on fleabay for $75. Maybe someone who reads this could chime in and tell me if that's a bad idea... an M5 front w/ the Z8 rear.
Old 02-24-2012 | 10:03 AM
I sold tires for years ALL tire reps told us the same thing, "never mix tires, don't even mix an old front with a new rear." That being said racers mix tires all the time some tires react differently than others, I had a matching set once that gave me a shake when together put a mixed rear on and it went away. Unfortunately the only way to know it has an adverse effect is to mount and see. Sorry
Old 02-24-2012 | 11:37 AM
speedkelly@aol.com's Avatar
I'm big fan of Bridgestone tires. My current bike (Tuono) has the BT-016pro's on it. I can't really tell any difference from the regular BT-016's. I will say this, all you really need for fast street riding is this tire. You can always find these tires on sale. Only minor let down is they tend to wear just a little quicker than other brands. I rode these tires on track without any issues. Great allround sport tire. Not really a touring tire.
Old 02-24-2012 | 12:35 PM
aja's Avatar
aja
Ive been running a michellin pilot road 2ct dual compound on the rear and love it. It's got about 2k very hard miles on it as well as about 2k in commuting and still has tons of life left. I've never had any grip problems in the rain or cold weather, there's been times when my 023's would slide and I can push the 2ct way beyond that without having any doubt.
cliby
11-07-2010 10:33 AM
joedirt5
02-04-2009 11:03 PM
reaper
12-03-2007 09:47 PM
MotorToad
09-12-2007 03:14 PM
rray
02-21-2005 04:47 PM
