My first VTR, well most of one
Old 01-19-2009 | 09:55 AM
  #151
The exhaust needs to line up with the bodywork. If you're really gonna angle the subframe and seat like that I suggest you find a really good and comfortable athletic cup.
true.. that or a sex change.. Looks very euro with the *** way up like that, it works but if I were riding it I'd want something that puts a little less pressure on the jewels.
Old 01-19-2009 | 11:44 AM
  #152
Oh... and a side note... even if you do that crazy angle... keep the seat a bit more backwards as it is in stock form... Starts on the back edge of the alu frame behind tha tank... otherwise not only the angle will bother you, you will also have a hard time getting your feet on the pegs as they will be to far back... Plus you will move your weight alot forward on the bike...
Old 01-19-2009 | 11:55 AM
  #153
hawxter996's Avatar
ole dirty bastard
nothing wrong with putting more weight up front.
if anything it would probably improve handling.
plus he mentioned making his own rearsets.
lets see what ole dr. frankenstein has in mind!
Old 01-19-2009 | 11:58 AM
  #154
Oh I'm waiting... Don't worry... I wanna see where this goes...
Old 01-19-2009 | 02:14 PM
  #155
Truckinduc's Avatar
1st off. The exhaust is nothing like that. It will be under engine with 2 Moto GP style shorty megs sticking out of each side.
The seat will be slightly lower but it will have more of an *** shape, more contour so i wont want to slide forward as much.
Ill be raising the rear ride hight and moving weight forward to improve turn in..
The handlebars im using will move my hands slightly up and slightly back. In turn ill have a more upright seating position.
Old 01-19-2009 | 02:18 PM
  #156
Truckinduc's Avatar
im using the stock upper subframe mount as my lower subframe mount. There will be no exposed subframe and it will look like the tail is supporting myself. To do this i have to move the seat slightly forward, but not much.
The final seat position will be determined by me sitting on the bike and how i like it.
Old 01-19-2009 | 02:21 PM
  #157
Truckinduc's Avatar
see
Old 01-19-2009 | 02:40 PM
  #158
Like I said, looks good.. I hope you can get it comfortable too.
Are you healing up much yet? It sucks to have a sickness drag out.
Old 01-19-2009 | 02:45 PM
  #159
Truckinduc's Avatar
actually ive started to feel better. Thanks
Old 01-19-2009 | 03:04 PM
  #160
finepooch's Avatar
it appears that you're thinking things through. gee, i wish at 19 i knew half of what you're displaying here! i'm 36 and learning lots from you!!!
it seems you aren't scared of anything!!!
when this is over you might have something from nothing. then when you're done you can sell it for hopefully a profit! good for you!
Old 01-19-2009 | 04:12 PM
  #161
Truckinduc's Avatar
well i do what i can. Thanks. Ill post up everything as i go so hopefully people can learn from it.
OK PEOPLE THIS IS WHERE I NEED YOUR HELP.
I need the height off the ground of the swingarm pivot point while the bike is standing up.
I also need the measurement from the top of the tire to the bottom of the bottom triple tree.
I put the bike back together and im setting the base line suspension height.
THANKS PEOPLE
Old 01-19-2009 | 04:38 PM
  #162
hawxter996's Avatar
ole dirty bastard
what swingarm are you planning?
your sketch looks like a 1098.
Old 01-19-2009 | 06:01 PM
  #163
Truckinduc's Avatar
stock one for now.
Later I may fit up a 600rr swinger, but i need this bike to ride soon.
Your right the sketch is straight up 1098. If i could get a 1098 swinger wheel and all components for 100 bucks id do it. I think we all know thats never gonna happen.
Old 01-19-2009 | 06:25 PM
  #164
Truckinduc's Avatar
Old 01-19-2009 | 06:49 PM
  #165
j shizzy wizzy's Avatar
mildly retarded
Thruxton just kicks ***!
Old 01-19-2009 | 08:18 PM
  #166
THANKS PEOPLE
Hmm, well my front suspension is funky (not right) and I don't have anyone to hold the bike to measure the rear, otherwise I'd do this.. Unless measured on it's kickstand works for you?
Old 01-19-2009 | 08:30 PM
  #167
Truckinduc's Avatar
Kickstand will work too, just not as accurate. I actually dont need the front measurement, just the rear
Old 01-20-2009 | 03:38 AM
  #168
stock one for now.
600RR swing wont fit... not even with your skills... Its one solid pipe all the way at the pivot bolt... (ie no overlapping between frame and swing as stock) 1000RR is the same...
However CBR 929/954 works with a lot of work... needs a new header and moving the suspension... plus a lot of fiddling since it's a 25mm pivot bolt...
RC51 swingarms fit with a little less work... an SP2 one is almost bolt on... SP1 has a larger pivot...
Also apparently for single side an Augusta MV4 swing shouuld fit...atleast it fits a VFR...
Old 01-20-2009 | 03:42 AM
  #169
There is this one... Should be good to go as the damage looks very minor...
http://cgi.ebay.com/Honda-RC51-Swing...3A1%7C294%3A50
BTW This is the 02-06 model ie SP2 and it's as close to bolt on as you will get... plus it's got that nice 3d look... Will need a set of different wheel bearings though...
Old 01-20-2009 | 06:51 AM
  #170
finepooch's Avatar
Old 01-20-2009 | 08:30 AM
  #171
Cool, I'll get that tonight if no one else has yet by then.
Old 01-20-2009 | 08:35 AM
  #172
Truckinduc's Avatar
I know this, and ive been doing my research on it. I CAN make it work.
I would cut the stock pivot point off the swinger itself. Remove about 2 inches up front because i want the swingarm shorter.
Ill turn a new solid billet pivot out of aluminum on the lathe, with notches where the center needs to be removed.
Get everything perfectly square and tack it together. And triple check everything.
Once everything checks out weld in the new pivot, and add extra bracing since I wont be heat treating it.
Then remove the center section where it mounts to the engine.
Thats how I would do it. Ive already got it all figured out, because im doing it on my Ducati monster once the SH is done.
Old 01-20-2009 | 09:02 AM
  #173
SlowHAWK's Avatar
You'll also probably have to fiddle with the lower linkage mounting and dimensions as well as the new RR's have the Pro-Link suspension... but the big benefit will be the elimination of the need to mount the shock to the upper frame like the VTR currently does... this will give you alot of room to make the exhaust work as necessary...
Old 01-20-2009 | 09:21 AM
  #174
Truckinduc's Avatar
yep, thats the idea
Old 01-20-2009 | 11:53 AM
  #175
Truckinduc's Avatar
the upper subframe rail sits at 31 inches. It will be close to 33 when its padded. My dads buell is 33 and im comfortable on it.
Old 01-20-2009 | 01:22 PM
  #176
Truckinduc's Avatar
Old 01-20-2009 | 02:09 PM
  #177
With all these changes to suspension you really need to be careful in how you get the bike set up. Do some calculations on rake and trail and shoot for numbers that are fairly close to stock. Raising the rear and lowering the front reduces rake to points approaching instability (and possibly beyond). Moving the rider forward changes weight distribution and changes the requirements of both the forks and shock. Looks like either a Fox or a Penske on the rear already so be careful on linkage ratios or else spring and damping rates will be all screwed up as well.
Old 01-20-2009 | 02:44 PM
  #178
Ok, ok! I take it back... You can probably make it work... I just figured it would be A LOT easier with a non pro-link swingarm...
I'll gladly cheer you on...
The thing is that with the pro-link, and you shortening the swingarm mount... Then you will have to re-do the pro-link mount as well to make it all fit... And you will have to come up with a custom linkage to a bike with a different weight and weight distribution from the 600RR... Add to that the fact that you are changing the rider position and you have a whole lot of unknown factors in that equation, as Hawkrider is saying...
I'm kinda on the limits of my experience trying to calculate the maths for a decent linkage lenght with a SP1 swing... You are entering the land of trial and error... Might work, might not...
I'm not a stranger to that myself... but I usualy like to at the least be able to calculate the odds of it working as I intended...
Old 01-20-2009 | 02:50 PM
  #179
BTW in your first few posts there is what appears to be a mock-up of the Monster with another swingarm, not a CBR swingarm... What is that one?
Old 01-20-2009 | 03:59 PM
  #180
Truckinduc's Avatar
Yes, the VTR will remain mostly stock. Suspension and frame wise nothing will be changed.
I will be building my own suspension for the monster, hell im also building a frame and a girter front end.
Thats a 999 swingarm on the monster in the picture.
I started on the rearsets a little while ago.
sorry for the shitty cell phone pics, my camera took a **** on me.
Quick Reply: My first VTR, well most of one
