My first VTR, well most of one
Old 02-27-2009 | 09:15 PM
  #391
Truckinduc's Avatar
Umm its a tank looking thing. doesnt do anything
Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People Comments People
Old 02-27-2009 | 09:54 PM
  #392
Syclone's Avatar
Boosted
Comments: You've got a lot of **** in your garage, I'm surprised you're not putting USD forks on the 'Hawk, and I think those headlights would look good with a plastic/fiberglass/carbonfiber surround.
Old 02-27-2009 | 10:18 PM
  #393
Truckinduc's Avatar
Im planning on doing something around them. Linda like a duke 690 maybe. It needs something though.
Old 02-28-2009 | 06:28 AM
  #394
andy9743's Avatar
i love naked bikes...your duc was bad a$$ i'm sure the hawk will look better. flat black is beautiful, the bed liner ballsy and smart. 20 years old wow. keep it up this thread is unreal!
Old 02-28-2009 | 06:59 AM
  #395
sumthin_major's Avatar
Is that an old Moto Guzzi in the corner with a flip top lid on it. Also, what wheels do you have on your supermoto project? Did you have to add spacers or anything.?
Old 02-28-2009 | 03:31 PM
  #396
Truckinduc's Avatar
That would be the Naught. Its a bike my dad built.
My SM had ducati monster wheels on it now. They are not staying on it. Ive got a gsxr front wheel and I dont have a back wheel yet. The monster rear tire is a 180. Ill probably be running a 150 on the rear.
The easiest wheels to put on would be cbr f2 or f3 wheels. They are the right widths and only require a bearing swap and spacers made. Its the wheels I want. I know where a pair are for sale cheap, if I had the money I would pick them up.
you need wheels for your crf right?
Old 02-28-2009 | 05:29 PM
  #397
finepooch's Avatar
looking at the pics of your garage i feel like i'm trying to find waldo! awesome!
Old 03-01-2009 | 05:57 AM
  #398
I do need some for the crf. I'll be looking around for some. I been checking around and I cant go any wider in the back than a 160, and even then it will rub. That Naught looks cool , but I bet it's uncomfortable to ride. Being a rigid and all.
Old 03-01-2009 | 03:15 PM
  #399
Truckinduc's Avatar
subframe fun has begun
Old 03-01-2009 | 06:30 PM
  #400
Truckinduc's Avatar
Old 03-01-2009 | 06:33 PM
  #401
Truckinduc's Avatar
The piece of wood is a mock up battery. The top rails also get some more bends.
Old 03-01-2009 | 07:00 PM
  #402
oahu hawk's Avatar
geezer
that battery gonna be happy sitting on top of the valve cover?...
Old 03-01-2009 | 07:09 PM
  #403
Gregw's Avatar
Hi Thruxton,
Just my opinion, but I think once the seat padding is on, the rear sub-frame will be too high. I am enjoying this thread, I wonder if it will catch up with the "Post Whoring Newbie Thread" More useful information in this one already.
Old 03-01-2009 | 07:20 PM
  #404
Truckinduc's Avatar
there will be an 1/8" gap and heat shielding, so I dont see it as a problem.
Originally Posted by Gregw
Hi Thruxton,
The subframe will sit about 32.5" and Ill have around an inch of padding, so it wont be too high.
My legs are long enough even though im only 5'11", Thanks for your concern though.
Old 03-01-2009 | 08:30 PM
  #405
kai ju's Avatar
My legs are long enough even though im only 5'11", Thanks for your concern though.[/QUOTE]
With the VFR tank my seat is at 34" and I'm 5'11" as well.
......and I have a 30" inseam.
So unless your legs are shorter than mine it won't be a problem.
Have you considered placing the battery behind the steering neck ?
Since you're fabbing your own tank, you can move the air intake to accomodate the battery in that area. ( Nothing worse than somebody else telling you how to build your bike..............)
Kai Ju
Kai Ju
Old 03-01-2009 | 08:39 PM
  #406
Truckinduc's Avatar
all my electronics are going behind the steering neck. The battery wouldnt fit anyway.
I dont see anything wrong with the location. My monster's stock battery location is similar.
As long as I shield it from the heat it should be fine.
Carbon fiber with aluminum tape should shield from about 95% of the heat.
OPINIONS?
Old 03-01-2009 | 08:41 PM
  #407
Truckinduc's Avatar
Ive been building the subby to fit a VTR radiator. I dont have the radiator yet, so if it doesnt fit I may have to cut this one up.
6.25" between the lower rails. Will it fit?
Old 03-01-2009 | 09:21 PM
  #408
kai ju's Avatar
Yes it will.
Stock radiator is 1 3/4x6x13 if you ignore all the miscellaneous brackets and spigots.
With your fabrication skills that shouldn't be a problem.
Kai Ju
Old 03-01-2009 | 09:28 PM
  #409
Truckinduc's Avatar
alright. someone measured one for me today and came up with 6.75".
Ill remove all the brackets and move the inlets and outlets.
Kai Ju do you have any predictions about the running temp of my bike?
Old 03-02-2009 | 07:35 AM
  #410
kai ju's Avatar
I just remeasured and, using the endcaps as the largest dimension, I stick with the numbers I gave you before. Consider that this is as small as you can make the rad and will require removal/relocation of spigots and mounting brackets.
As far as predicting what the running temp will be depends on the amount of airflow you will get.
If you look at my bike you'll see my side intakes on the rear cowl.
In hot weather they help, in cold weather they don't.
My bike's cooling system works because I have two fans.
It only needs one for around town, canyon work and constant speeds below 75-80.
Once speeds stay above 80, especially in high ambient temps, the second fan is needed.
That said, with both fans going, my bike runs cooler than most VFR's and RC51's, with high temps being in the 230's.
I routinely hear of VFR's and RC51's running in the 240-250 range.
You will be using half the surface area of a stock VTR in a location that doesn't promote airflow.
I've tried ducting to force air in, which didn't work.
If you can configure ducting that extracts the air from the radiator you'll be way ahead of me.
My goal was to make the bike look as Factory as possible which has limited my options, yours aren't. Have fun and go with it.
Like probably the rest of us, I hit your thread several times a day and wish I had your skills, kudos to your dad for teaching you, kudos to you for running with those skills.
Kai Ju
Old 03-02-2009 | 11:52 AM
  #411
Looking good! I am curious what you will come up with for your air filter / airbox situation.
Old 03-02-2009 | 03:33 PM
  #412
Truckinduc's Avatar
Old 03-02-2009 | 03:36 PM
  #413
Truckinduc's Avatar
Old 03-02-2009 | 04:02 PM
  #414
finepooch's Avatar
did you tap the inside of the frame to mount the front of the sub frame?
big time kudos out to you!!! i too check this thread several times a day. i'm hooked. better than the dukes of hazzard when i was a kid! yes truck, i'm a lot older than you!
Old 03-02-2009 | 04:17 PM
  #415
Truckinduc's Avatar
Yes I drilled and tapped the inside of the frame. I also made aluminum bungs that are threaded that will make the mount alot stronger. I just have to weld them to the frame now. Ill weld them next time I drop the engine.
Also gonna gusset the subframe with some plate to make it more rigid.
Old 03-02-2009 | 06:48 PM
  #416
kai ju's Avatar
Did you leave yourself enough room to the get the valvecover off without unbolting the subframe in the front ?
On the other hand, you only have to do so every 16000 miles.
So it's not that big of a deal, except for the plumbing, maybe.
Can't wait to see your radiator solution.
Kai Ju
Old 03-02-2009 | 07:00 PM
  #417
Truckinduc's Avatar
nope. Unbolt the subframe at the front and tilt it back a little. Im using every inch of space on this thing.
Old 03-02-2009 | 07:09 PM
  #418
Truckinduc's Avatar
gusset patterns
gussets done. I got lazy, Ill weld them in tomoorrow
Old 03-02-2009 | 11:09 PM
  #419
I don't know how much it will help, but remember that hot air naturally rises and that fighting that natural flow will work against you in your fight to keep things cool. I don't know what your plans are for a tailsection, be it stock, R1, Gixxer, etc. If there's any way to run the fan(s) to take advantage of the natural airflow then that would be the way to go, having the fan(s) pull the air up and out rather than blowing down and out. Also, don't forget about a hugger to help keep the rad clean and prevent busted fins.
PS It'd be interesting to see the mockup with the tank installed and you sitting on the bike. My initial thoughts are "ouch"!
Old 03-03-2009 | 08:38 AM
  #420
Truckinduc's Avatar
I posted this on another thread a while back. Puller fans, heat exits out the low pressure area behind the back.
I will NOT be running a hugger as I hate the way they look. Ill protect the radiator in other ways.
And Im not using any stock style tail, gsxr, r1, anything like that. Im designing and building my own.
Quick Reply: My first VTR, well most of one
