How harmful are backfires?
So i was wondering how bad are backfires for the engine? Are the pulses produced from the explosion outside the combustion chamber powerful enough to disturb the exhaust gases and burn an exhaust valve? Im asking this because i was making my bike backfire the other day by playing with the kill switch so i'd like to have your opinion on it. Thanks
I believe the proper term would be after-fire, or after-burn. They do happen on occasion and it's usually not a big deal. Mine does it sometimes during startup if it doesn't fire up right away. However, I would not recommend intentionally generating an after-fire. This phenomenon is obviously not a part of the normal operating conditions and IMO should be avoided if at all possible. I would think the pressures could possibly damage the header or other parts of the exhaust system.
In general they aren't going to hurt anything if they happen say on decel due to a lean or rich condition. But those are generaly relatively small. However when you cut the ign. off there is way more fuel going into the exhaust and when you turn it back on and it lights off it has a lot more power. You could potentially blow out a muffler or exhaust pipe, though those parts on these bikes are pretty well built. You wouldn't ever burn a valve per se however if it was bad enough it could potentially blow the exhaust valves open and if your timing was just right you could potentially have the valve hit the piston. This would be a very extreme case and highly unlikely.
So I guess the short answer is no it generally won't hurt the bike, however if you do it big enough there is the potential to cause some dammage.
To the engine? Very little. To pedestrians in the 3rd street tunnel in downtown Los Angeles! pretty scary!
1/ Enter tunnel
2/ open throttle slightly
3/ hit kill switch for a second or two
4/ turn on kill switch. KABOOM!
repeat as needed? You can pretty much go Bang Bang Bang with the kill switch. My little son use to think it was great when I would ride along side my wife on the freeway and do this, I would make the gun sign with my clutch hand and work the throttle kill switch with right hand.
Only works on Carb'd bikes.
Fun! what motorcycles are made for.
1/ Enter tunnel
Yes! I'm sure there are a few pedestrians in the 3rd Street tunnel. That are glad a certain motorcyclist has a fuel injected bike right now!
Backfires for me are like wheelies, all part of the fun of owning a motorcycle.
Sherm831
05-18-2010 08:07 PM
