How do you change rearsets?
Old 07-16-2005 | 01:30 AM
mykrowsy's Avatar
mykrowsy
I recently crashed my bike, and one of the damages incurred was a broken right rearset. I'm considering replacing both rearsets with some aftermarket rearsets, or maybe I'll just have the broken one welded up.
I heard that replacing the rearset requires me to remove the swingarm to do so. If I need to do this, which I don't want to do, I think I just might have the stock broken rearset welded up by a shop right on the bike.
Has anyone done this? If so, what is involved, and what is a good inexpensive option for the aftermarket?
thanks,
mike
Old 07-16-2005 | 03:11 AM
Monomaster's Avatar
Monomaster
Re: How do you change rearsets?
If your careful & support the bike under the sump & tie off the side so the bike doesn't fall, you should be able to simply ease out the swing arm pivot bolt, change the righthand footpeg & re-install the bolt again. you shouldnt have to touch anything else...
Old 07-16-2005 | 06:11 AM
cdyer77's Avatar
cdyer77
Getting the axle bolt out can be a pain inthe ***! I dont know how well a piece of cast alum will hold up to be welded? I would just take the plunge and get some aftermarket rearsets. Its a little work to get them on, but think of the knowledge youll gain in doing it.
correll1000
09-18-2011 09:52 PM
Sherm831
05-18-2010 08:07 PM
Randman
03-30-2007 06:38 AM
NOrrTH
11-25-2005 10:59 AM
