Hawk eating batteries v.need some advice
Old 05-22-2008 | 12:52 PM
quakefiend420's Avatar
quakefiend420 is on a distinguished road
so i've been through 2 brand new batteries now...voltage regulator checks out good .3 ohms across the board, same for the alternator...however i'm only charging at 12.4v @ 3000rpm...is it safe to assume i should replace the alternator stator?
Old 05-22-2008 | 01:16 PM
Derek's Avatar
Derek is on a distinguished road
I have the same issue and i replaced the regulator hoping it would fix it, it didn't.
Old 05-22-2008 | 01:23 PM
RickB's Avatar
Check the output at 5000rpm, it should be in the 14v range. Also check the battery cables for any corrosion and make sure they are all tight. You can find the service manual on the site if you don't have access to one, it may help you go through the troubleshooting process.
Old 05-22-2008 | 01:58 PM
lowell's Avatar
Simi Valley, CA
lowell is on a distinguished road
I had the same conditino on the VFR 4 years ago.
Went thru 2 batteries.
Replaced the R/R and lost another battery.
Opened up the case to the Stator and saw 2/rds of the windings black and not a light brown. replaced the Stator and Bang 14.8 v constant.
The R/R was still good and the old batteries were also fine.
http://www.electrosport.com/technica...ding-guide.php
is a guide I used to determine what is happening
Old 05-22-2008 | 03:34 PM
Derek's Avatar
Stator it is then, thanks.
Old 05-22-2008 | 03:35 PM
it isn't, and i also checked the battery cables, they're fine
guess i'm replacing the stator...where should i look to get one for teh best price?
Old 05-22-2008 | 03:52 PM
FTMS's Avatar
Try Rick's Motorsports Electric's 1-800-521-0277. They will exchange it for a rebuilt one or rebuild yours if they don't have any on the shelf.
Old 05-22-2008 | 08:40 PM
happytrack44's Avatar
WERA #44
Check for static (key off) drain on battery. Killing the battery, jumpin, and recharging will eventually destroy it. Your charge system may have no problems.
Old 05-23-2008 | 12:01 AM
BeerHunter's Avatar
Slacker
Originally Posted by quakefiend420
r...however i'm only charging at 12.4v@3000rpm...is it safe to assume i should replace the alternator stator?
That must be the strangest email address I have ever seen....do some more tests on the stator before condemning it. I have seen a great many electrical problems cause by corroded contacts and/or loose fitting terminals, more so than from actual bad components. [DISCLAIMER...these comments apply to electrical systems in general, and are not meant to be seen as SuperHawk specific]
Old 05-23-2008 | 02:45 AM
no parasitic drain at all with the key off, pulls 6 amps or so with the ignition on and the bike off
and i've already been through two brand new batteries, so i'm pretty sure the battery isn't the problem
Old 05-23-2008 | 08:07 AM
rbrais's Avatar
Keep the batteries and hrow them on a good charger (not trickle charger). They should come back.
Old 05-23-2008 | 11:36 AM
i'm figuring they probably will
eersfanpilot
11-24-2010 01:05 PM
cel2620xl
05-01-2010 01:06 PM
Anto
09-02-2007 07:36 AM
Doc
08-25-2007 05:39 PM
99Hawkboy
07-04-2005 12:02 PM
