Front stand and lowering the front
Old 04-17-2008 | 12:46 PM
TheRezyReb's Avatar
TheRezyReb is on a distinguished road
Looks like if I lower my front the 10mm, I may not be able to use my front stand. Any one have any idea on this?
Old 04-17-2008 | 01:02 PM
I have my forks pulled up 10mm and my pit bull stand works just fine.
Old 04-18-2008 | 12:10 PM
PRTSMN's Avatar
PRTSMN is on a distinguished road
OKAY QUESTION,HOW DO YOU LOWER THE BIKE THAT IS SOMETHING I WANT TO DO?
Old 04-18-2008 | 12:19 PM
TheRezyReb's Avatar
As far as the front, loosen the upper and lower triple clap bolts.
Old 04-18-2008 | 01:44 PM
PRTSMN's Avatar
DOES THIS IMPROVE OR HURT THE WAY THE BIKE HANDLES
Old 04-18-2008 | 01:46 PM
TheRezyReb's Avatar
Lowering the front will make the bike turn in quicker. Thinking of lowering front and raising the rear.
Old 04-18-2008 | 02:39 PM
PRTSMN's Avatar
SO JUST LOOSEN CLAMPS AND DOWN IT COMES. TIGHTEN DO YOU HAVE TO MEASURE THE DISTANCE.
Old 04-18-2008 | 03:40 PM
TheRezyReb's Avatar
Well, it's a lil more complicated than that, but yea thats a simple way to put it. Yes, you need to measure it.
Old 04-18-2008 | 04:44 PM
Yes you must mesure the amount you pull up the forks. You should go in small steps as it will change how the bike handles. Start with 5mm and if you like that try 10mm. Don't go anymore than that, I only say that because at 15mm my header would hit in right hand turns.
Old 04-18-2008 | 04:56 PM
PRTSMN's Avatar
IN YOUR OPINIONS, WOULD YOU PERFER IT LOWER FOR LOOKS AND TURNING. OR JUST TURNING
Old 04-18-2008 | 07:03 PM
It really doesn't change the look of the bike as 10mm is less than 1\2"
lukenukem47
10-08-2010 12:02 AM
dannyz
08-14-2009 08:19 PM
KindredGhost
02-10-2008 12:43 PM
tucklo
05-02-2007 04:55 PM
SNGPerformance
12-15-2006 08:42 AM
