Fitting a CBR600RR rear wheel?
First things first: yes I did a search and found oen thread that dealt with the matter of fitting a CBR600RR rear wheel to the VTR. However, the last post dates quick a little while and nothing conclusive came of the thread anyhow.
So, with that out of the way, has anyone tried or succeeded at fitting a CBR600RR rear wheel to the VTR? If yes, please share what was involved.
thanks in advance.
thanks in advance.
Nope. am running a PVM rear wheel for a CBR900RR (same dimensions as VTR). However, as I hunt for a 2005-2008 GSX-R front wheel to accomodate the CMC rotors I bought, I need to find a matching rear and suffice to say hardly anyone makes aftermarket wheels for the VTR. If a 600RR wheel can me date to fit, however, I can simply mix and match a 600RR rear with a GSX-R front from a given aftermarket model (which opens up a whole list of possibilities, inclusing Dymag, BST,....) and all will be well with the world
Don`t be shy now.... any info that could potentially be helpful would be appreciated (ie. 900RR wheel mounted on CBR600RR,....). As the 900RR, for example, is dimensionally same as VTR (for mounting purposes), any info related to a swap involving it could be useful.....
Can't help you here but was curious what the advantage is for fitting a CBR900RR wheel to the VTR is, and what is needed to do so? For example is it lighter, wider (6" vs 5.5"?), have better more robust bearings, require custom spacers, is it the same color as a 98 VTR wheel, etc?
Thanks Jamie. Not having the necessary machine tools, however, it can be a hurdle....
BTW, to be clear, I am not looking to install an OEM 600RR rear wheel, but rather a 600RR-compatible aftermarket wheel (Dymag CF would be nice). If it boils down to trimming 2mm or shipping 2mm for the sprocket, it can probalby be done, anything a lot more complex likely puts it out of reach for me......
you're correct. I am hoping someone can provide me with the info needed to make them fit, save me from having to do the legwork myself....... Have done a fair amount of Google searching already and am confident they can be made to fit; however, nothing about the specifics involved.... hoping for an enlightened shortcut...... it seems I almost always end up doing the pioneering work on most of my projects, was hoping to ride someone's coattails for a change.......
New Info
I was speaking to a local guy who races an 05 06 CBR450rr (CBR600rr with 1 cylinder unplugged to fit capacity restrictions for F3/Superlites, lot of guys do it).
He said that his wet rear rim is off a CBR600 F4i, and only required a little bit of spacer work to make it fit. Brake disk and cush drive lined up correctly once the wheel was spaced correctly, and only needed bearings to fit the 600rr axle which is thicker.
Now I've read somewhere ( and I'm still looking for it again) that the F4i wheel is a direct swap for the VTR1000f...
Sometime in the new year, I'll be borrowing his wheels to measure, see exactly how different they are...
Well... As long as you use an RC51 swing arm as an adapter, it's easy-peasy...
If not, you run into the issue of 25 mm axle vs the VTR's 20 mm axle... Other than that the spacing is actually correct, so using the CBR600RR complete set of spacers, with cush drive is pretty much drop in... Apart from the axle issue then...
But, if you want too keep the stock swing arm and axle, you need to swap bearings for matching OD and 20 mm ID, all over...
BTW, the setup from Honda is amazingly "standard"... As long as you use the matching spacers, 9 out of 10 times the whole assembly of wheel and cush drive has the same alignment from bike to bike (CBR/VTR/RC51)... And the rear wheel brake disk is almost always correctly aligned....
So, basically the answer is, get a complete set of wheel and cush drive, get a set of bearings from All ***** or similar, and double check, it's entirely possible you can use the VTR's stock spacers...
This thread is now useless for Mike. He's got himself some killer carbon wheels he'll be toying with over the winter.
However, still is valuable info for anyone else interested in this mod...:O)
CruxGNZ
04-24-2014 08:49 PM
