check your buttons
Old 04-03-2011 | 05:34 PM
uchi's Avatar
check your buttons
for those with full floating rotors, check them every once in a while. my brakes were fine and i had zero slack in them last year and even this year, but i took the wheel off for something and must have shaken the crap out from around the buttons. ive always had a little side to side play but i noticed i had alot of front to back play on there, alot more than i ever had. anyways, replaced the buttons with new ones today, and were back in business. once i figured out a little trick to get the c clips back on i was about to do each rotor in about 5 minutes after removing it. even made a little before and after video.
YouTube - full floating rotor button slack
Old 04-03-2011 | 11:06 PM
Good to know, man. Always nice to learn from other experiences.... and nice to know that it's only a 5 min (post wheel removal) fix.
Old 04-04-2011 | 04:28 AM
uchi's Avatar
yeah ots really easy once you figure out how to get them on and off. removal is simple, i used a small flat head screwdriver, shoved it under the clip where it opens, pried up and out they come. you can put them in with 2 screw drivers but that takes a while. i ended up using a pair of spanning pliers, when you squeeze them together the end opens up. i opened up the new clip just enough to get it to go on the new button and then it would stay there by itself, and then id click it into place with a flat screwdriver by just pushing down. simple enough to do.
jay956
02-28-2012 11:02 AM
Wolverine
12-09-2010 06:13 AM
luis saleiro
04-25-2010 04:25 PM
nnjhawk02
06-18-2009 12:51 PM
divingindaytona
04-13-2009 05:44 PM
Quick Reply: check your buttons
