Cheap Honda brand Oil FIlters, Oil, & drain plug washers
Posted this on another topic but it deserves it's own
Cheap honda oil filters, honda oil, drain plug washers, & other stuff....
http://www.hondadirectlineusa.com
Altho it's a cruiser web site you will find your Honda oil filter is the same. Only $6.99 - check the part number !!!
Same deal with the washers - check the part number !!!
See the micro fiche at Ron Ayers to cross check part numbers
http://www.ronayers.com/fiche/getdesc.cfm?man=ho]
filter - 15410-MCJ-003 $6.99 each
http://www.hondadirectlineusa.com/st...10&ID=68467410
oil plug washer - 94109-12000 12mm (package of 10) $5.40 (these are cheaper at Ron Ayers but not when you figure extra shipping costs)
http://www.hondadirectlineusa.com/vt...45&ID=68467410
Honda oil by the case
Free shipping
$5.00 handling fee if order less than $100.
No handling fee if order over $100
Free shipping
I've reused the one on my goldwing since new. Never any problems. I couldn't see the logic in replacing each oil change unless it's damaged in some way. I just give a quick visual inspection, and back on it goes. (Prob. 8 times now)
Don't forget about this thread with cross ref #'s I've been using the wal-mart super tech st-7317 for $2.30 and so far no complaints.
https://www.superhawkforum.com/viewtopic.php?t=1987
Nope. But if I did, I'd certainly replace it.
Re: Cheap Honda brand Oil FIlters, Oil, & drain plug was
I re-use washers as well. Annealing is the answer here. Heat it up and it becomes soft and will work like a new one.
I will also smooth mine over with a file too if it needs it, to ensure it is flat.
Thanks for the P/N on the wally world filter. That rocks !! Im almost to 500 miles on mine and Im changing the oil once I hit it. Im a freak about oil changing so this will make it cheaper/easier for me. Ill probably change every 1500 miles or so..
I have spent hours and days studying the damn HONDA oils and filters. I keep getting different numbers for the stock Superhawk oil filter number. Anyone have it? I am looking for the least expensive place to buy an oil filter online. I have found the MM9 on only a few websites. How many motorcycle filters does Honda offer?
OICDN did all the work for you last December:
Oil Filter Cross referencing...
For people who are curious, I searched and couldn't find anything....here's a list of cross referenced oil filters we can use on our Hawk.
I will never again, goto a dealer to buy a filter and dino oil (non-syn) for $25 ever again.....Well, atleast they helped me get a part number so I can cross reference stuff.....a buddy helped me find this info:
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
* AC Delco PF2135
* AMSOil SMF103
* Carquest 85358
* FRAM PH6017A
* Honda 15410-MCJ-000
* K&N KN-204, about $13. Metric nut on end for easy removal.
* NAPA Gold 1358
* Purolator ML16817. Imported, not made by Purolator.
* STP SMO 17
* WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
* Purolator Pure One PL14612, about $6.
* Mobil M1-108, about $12.
Made by Champion.
* Bosch 3300, about $6.
Made by Champion.
About 3.25 inches long.
* Purolator Pure One PL14610, about $6.
* Mobil 1 M1-110, about $10.
Made by Champion.
* Bosch 3323, about $6.
Made By Champion.
* WalMart SuperTech ST7317,
about $2. Made by Champion.
Automobile Filters, about 2.5 inches long.
* AC Delco PF1237
* Baldwin B1400
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* WalMart SuperTech ST6607
* WIX 51365
Automobile Filters,
about 3.25 inches long.
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Carquest Red B4620
* Casite CF240
* Castrol 7317
* Champion Labs Ph2867
* Defense Filters Dl7317
* Deutsch D-370
* Federated Filters LF240F
* Fram Double Guard DG7317
* Fram PH7317
* Fram Tough Guard TG7317
* Fram Xtra Guard XG7317
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Motorcraft Long Life FL-821
* Napa FIL1356
* Napa Gold 1356
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Gauge PGO-4620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Service Champ OF-4622
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
Viper, You might try the search tool sometime
Hope this helps...now you can just goto Autzone or whatever and snag up some filters...might help out the SHawk noobs (such as myself)
oicdn is offline Add to oicdn's Reputation Report Post Reply With Quote
These Oil Filters
2.3" O.D. gasket
2.5" to 3.5" long.
Motorcycle Filters.
* AC Delco PF2135
* AMSOil SMF103
* Carquest 85358
* FRAM PH6017A
* NAPA Gold 1358
* STP SMO 17
* WIX 51358
All have superior
filtering.
Made by Champion.
Made by Champion.
Made by Champion.
Made By Champion.
* AC Delco PF1237
* Baldwin B1400
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* WIX 51365
Automobile Filters,
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Casite CF240
* Castrol 7317
* Deutsch D-370
* Fram PH7317
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Napa FIL1356
* Napa Gold 1356
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
Sorry bro...maybe this will help
Part Number: 51358
UPC Number: 765809513587
Principal Application: Honda Motorcycles + Industrial Engines, I-R, Komatsu, Kubota, Kia (95-05), Mercury, Arctic Cat, Polaris, Subaru (06), Yamaha, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/52
Burst Pressure-PSI: 265
Max Flow Rate: 8-10 GPM
Nominal Micron Rating: 14
Part Number: 51358
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Part Number: 51358
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Part Number: 51358
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Try this bro:
up to 2002
Quality Parts Unlimited OEM replacement oil filters. OEM # 15410-MM9-013 / 16097-1061 / 16097-1063 / 3FV-13440-00.
after 2002
Breakthrough technology allows filter to trap particles down to 10 microns in size, conventional filters only trap particles no smaller than 20 microns.. Synthetic filter material allows motorcycle engines to last longer. OEM # 15410-MM9-013 / 16097-1061 / 16097-1063 / 3FV-13440-00.
http://www.gdlcycles.com/asp1/findme...00&cat=filters
up to 2002
after 2002
I change oil in my off-road bike almost every ride. Still on the factory washer. If it was leaking any, I would see dusty buildup around it. So far so good in 4 yrs.
Holy crap! Now we're down to oil washers???
I see all the heavies weighed in on this one. I guess that means everybody is having a very boring winter.
It has been no peach orchard here.
Some guys are riding here but it was 36F and misting all day. Nobody is having fun. These guys bought high and got caught by the cost of gas.
They gotta ride it. It's just too expensive to drive the truck.
Well at least nobody's started another "what's the best VTR engine oil" thread.
Besides, I'd rather talk about drain bolt washers all day long than watch 5 minutes of TV about Britney Spears or the dead Broke Back Mountain guy.
