Buying a used engine...
Old 07-28-2009 | 12:38 PM
Chester3000's Avatar
Chester3000 is on a distinguished road
Hey.
I'm about to go look at a used engine in the next few days.
What should I look for on these engines?
The guy says it has only 3000mi, and it was a strong motor before he crashed it.
I don't think the engine can be started, so I have to take his word for it.
I have tools and can do various tests, ie: compression, or valves, etc...
So what should be looked at on these bikes?
I know next to nothing about hawks Other bikes yes but these guys, no.
Thanks for any help.
Old 07-28-2009 | 01:06 PM
FL02SupaHawk996's Avatar
Fastest Color
Originally Posted by Chester3000
Hey.
Chester, unless you can pull the heads off and look down the holes there's not much you can do other than take the plugs out and turn the engine over by hand to make sure it's not seized...
Depending on the miles you may want to bore and rebuild it anyway using oversized pistons...
Old 10-13-2009 | 09:34 PM
Bridge_Boy's Avatar
Bridge_Boy is on a distinguished road
I have a 2002 Hawk will a complete 1998 motor swap into it without a great deal of work? My CCT failed and bent my front two valves. So if the swap is difficult rebuilding the head is my better option. A knowledgeable opinion would be greatly appreciated
Old 10-14-2009 | 09:54 AM
The basic motor never changed over the life of the bike. The only thing you'd have to swap off your old bike (to my knowledge) is the small thermosensor. (used by your digital dash) However reinstalling the engine into the frame requires tools only available from Honda. If your piston is not damaged from the valves hitting it, you could swap just the head.
Old 10-14-2009 | 10:41 AM
Those tools can be made using a socket of the right size (can't remember if it was 17 or 19 mm) using a file and hacksaw...
Old 05-25-2012 | 11:21 PM
Actually, you dont need to change the thermosensor cuz it stays with the fram and liquid cooling system. I thought the same thing before my motor swap a few months ago. How much is the motor?
Old 05-25-2012 | 11:26 PM
Well as it was almost 3 years ago.....
Looking for a used engine?
Old 05-25-2012 | 11:29 PM
OK it is officially past when I should've gone to sleep......
faz
08-31-2014 04:28 AM
memmakersorg
04-26-2013 05:04 PM
Damm1t
03-29-2012 08:48 PM
pwshadow
03-07-2011 04:37 PM
popcornchicken
Forum Feedback
05-21-2009 06:31 PM
