Anyone running CBR600RR/1000RR wheels?
Old 09-08-2009 | 09:48 PM
Just curious....
Old 09-08-2009 | 09:52 PM
Gregw's Avatar
My front be a 1000RR.
Old 09-08-2009 | 10:01 PM
assume you're running some USD forks?
Old 09-08-2009 | 10:21 PM
Gregw's Avatar
Yeah, forks, rims, calipers and fender are from a 1000. Someday I'll get around to putting that stuff in my sig.
Old 09-09-2009 | 10:29 AM
I'm running CBR 1000RR front 600RR rear, the reason being that the 600RR uses the same width 5.5" as stock...
They are considerably lighter than the stock rims, but needs a 25 mm axle so it won't work on stock fork/swingarm...
Old 09-09-2009 | 11:24 AM
I have a CBR1000RR front wheel, but it is to go with my USD forks. I don't think it'd work on the stock forks.
Old 09-09-2009 | 01:38 PM
Perhaps a bearing change (to a smaller 20 mm ID) would work though....
Old 09-09-2009 | 03:16 PM
Could be a possible solution yes... The bearings outer dimensions are pretty standard, so it should be easy to find a matching one...
But I still maintain that my method for fitting them, albeit more complicated is better...
J Bragg
02-04-2011 07:32 PM
red_rocket98
01-10-2011 07:31 PM
salmanilla2000
01-29-2010 11:58 AM
98blackhawk
10-29-2007 07:39 PM
