2nd gear roll on wheelies
My buddy just finished putting his bike back together after a bad crash. He's short on $$ and ended up cutting his carbon fibre D&D's in half and repacked em so they look stubby.
Thats the only thing different from pre-crash and now I can EASILY power the front up in 2nd gear.
Also, I have the -1, +2 520 set up (his gearing is stock) and we dragged each other and were neck and neck till I topped out when he obviously blew by me.
Now my bike could be better tuned for the hotter weather (set up for cooler) but holy crap, his bike goes like snot! Its made me quite depressed about mine now which was much faster than his to 220kmh pre-crash.
I've never been able to power wheelie in 2nd, not even a pop. It's tough to even get the front to leave the ground with the clutch. There's nothing wrong with my bike, quite the opposite in fact. It's got some internal engine mods plus the rear ride height is up over 1" (that would make it easier to bring up BTW). I do plenty of wheelies (daily) and even shift gears a little. However getting it to come up in 2nd has never even shown a glimmer of hope for me. I hear a lot of people talk about 2nd gear wheelies on the VTR but I'm a little skeptical until I see it for myself.
Also, I'm about 225lbs, I'm guessing that my friend who is 130lbs would have an easier time with it. Maybe that's the variable that I'm missing...
I could be wrong... but wouldn't raising the rear ride height limit your ability to lift the front??? You'd have more weight forward on the front with the rear raised, therefore making it harder for the front to lift.
J.
J.
I'm 5'11" and around 218 lbs and I can get second gear power wheelies going up or down slight gradients with a pull on the bars. Clutch wheelies in second gear are no problem even at higher speeds and I have stock gearing. Jaimie, where are your rpms and throttle position when your popping the clutch in 2nd ?
Originally Posted by mikstr
You may want to crash yours too then
Nope, adding ride height makes the bike easier to wheelie. Why do the drag guys lower their bikes? My bike also has stock gearing. I've tried multiple rpm's and throttle positions including WFO. I've gotten the front to pop up maybe 6", but that's it. Side note - I don't do stand ups nor do I jump up and down on the pegs to help it out. Just throttle, clutch and a good tug on the bars. A good friend of mine is the best wheelie guy I know and he can't do it either by the way.
As mentioned, this is my second VTR the other being a brand new one. I can say for sure that there is nothing wrong with this bike, with the mods it runs very strong. At 14k miles my original clutch might be feeling the hurt which could account for that part. This bike will get the front light (tank slapper kind) out of both 2nd and 3rd gear corners, but there is no way it will lift.
Don't get me wrong, I'm not trying to say that anyone is lying. I'm just a skeptical kind of person, I need to see it to believe it.
Now a 2nd gear wheelie was never an issue with some of the big boys like R1, CBR1000RR, or a GSX-R 1000 (140+ HP with 70+ ft-lb of torque). My friends do stand-ups in 2nd with their inline-four 1000’s all the time, sometimes in 3rd. You can tell a HUGE difference in power delivery when you ride a gixxer1000 after riding the super chicken. But again, I love my life and I also love the unique V-Twin grunts that other bikes don’t have.
SPEED SAFE!!
7000rpm doesn't seem like very much room to ride it out. Mine will run to 10.5k before the limiter kicks in, but even so it seems like the experience would be short lived. I've noticed that leaving it in 1st makes for quick up-and-downs because the revs go by so fast. I usually end up shifting. I'll give your method a try just to see how it works.
My bike also has stock gearing but I can still get a 12' o clock clutch wheelie out of it in second (not on purpose normally !). I generally start at 5K and whack the throttle then pop the clutch and she comes right up. You can then feather the throttle to hold the bike up then switch to third when the front starts to come down. With first gear power wheelies I normally shift to second to try and ride it out as well. The amount in the gas tank doesn't seem to have a noticeable effect that I'm aware of either.
I forgot to mention that with second gear roll on wheelies it is definately harder to find that sweet balancing spot. Using the clutch has way more consistency.
SlowHawk is correct. All other things being equal, raising the rear makes it more difficult to wheelie because it puts more weight on the front.
I don't know about the second gear wheelies stuff. Mine won't do it, but I don't try very hard.
You should try an adjustable length shock sometime. You'd find out exactly how much easier the front lifts when you raise the rear. Also, if you measured the weight difference F/R you'd find an negligible difference. It's all about center of gravity, force vectors, etc.
I have tried an adjustable length shock. You're right, it's about geometry and leverage and traction and all that physics stuff, but raising the rear or lowering the front make wheelies more difficult while lowering the rear or raising the front make wheelies easier.
The (relatively) small amount we alter the ride height of the Super Hawk probably doesn't make all that much difference, but raising the rear does make wheelies more difficult, as does strapping the front down and lengthening the swingarm and all those other tricks used by drag racers.
I could prove it if I slept in a Holiday Inn Express.
EngineNoO9
07-13-2006 07:06 PM
