RC 51 Front brakes
Old 04-04-2007 | 12:10 AM
KC-10ENG's Avatar
RC 51 Front brakes
These are not mine but a good upgrade for someone!!
http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem
Check out his other items also he has a set of forks!
Later Dennis
Old 04-04-2007 | 08:52 PM
Will the calipers just bolt on the VTR????
Later Dennis
If so, I'll go for it!
Old 04-04-2007 | 09:26 PM
I am running this set-up (plus steel lines and EBC HH pads) and HIGHLY recommend it
Old 04-04-2007 | 09:50 PM
Randman's Avatar
Moderate-whore
wow nice feedback,,,NOT...I don't deal with anyone that has less than 98% and then I read the negs that brought them down to 98%....It's a trust thing really...
otherwise looks like a nice setup...I went with the stock MC, and those calipers...regular pads, they are an improvment over stock for sho...Need to get some EBC pads for them...
Old 04-04-2007 | 10:19 PM
Questions
1. Will the 04 RC-51 calipers bolt right up and work on the OEM VTR rotors, and use the same mounting bolts and SS lines on my VTR?
2. Are you saying you would NOT buy from this guy?
Time is running out and inquiring minds need to know.
Thanks
Old 04-04-2007 | 10:54 PM
YOu need to grind away a little bit of material from the underside of the caliper to mount them. Do a search, there is existing info about this.
Old 04-05-2007 | 12:12 AM
Yes, I found the thread
It was under brake system overhaul.
Problem is, Slowhawk does not say if VTR lines and banjo bolts will work...
Old 04-05-2007 | 12:32 PM
Randman's Avatar
Moderate-whore
Yes they fit I had ss lines already on when I did it...you grind a little, use a drill and a bit made for sanding worked best for me, better than drimel...
the lines bend just a bit, as if they are a smidge longer, but no worries they work...mind works fine....
Old 04-05-2007 | 12:34 PM
Randman's Avatar
Moderate-whore
oH, and I was not saying not to buy from this person, it was just my opinion, I don't personally do business with anyone that has less than 98%, I mean not very many will have 100% including me at 99.8% there are stupid people out ther you have to account for....
Firehawk_ordie
04-17-2007 09:13 PM
tophyr
03-19-2007 05:13 PM
mhutch
11-27-2006 05:23 PM
EngineNoO9
11-25-2006 09:15 PM
superbling
05-21-2006 09:25 PM
