WTB: Factory Pro +4 Ignition Advancer
Old 02-16-2014 | 08:57 PM
dudeitscristhian's Avatar
dudeitscristhian is on a distinguished road
It seems this is a popular mod and my hawk needs to be spoiled.
Old 02-16-2014 | 09:13 PM
thedeatons's Avatar
What year is your hawk?
Old 02-17-2014 | 04:35 AM
I have a 2002 hawk, thwdeatons.
Old 02-17-2014 | 05:57 AM
pchrist's Avatar
pchrist is on a distinguished road
How can you tell if you have this mod done? What are the benefits. I have a 98 possibly looking at doing it
TY
Old 02-17-2014 | 01:07 PM
HRCA#1's Avatar
If I remember correctly the 2002-2005's don't benefit from the +4 as it's already programmed into the ignition module. The +4 only helps 98-2001 (and it may be that the 01's have the newer ignition not sure on that one)
Old 02-17-2014 | 01:12 PM
Appletonhawk's Avatar
Appletonhawk is on a distinguished road
What is this and what does it do? I have a 2000.
Old 02-17-2014 | 01:48 PM
Just what it sounds like,, statically advances the ignition 4 deg.
All it is, is a trigger star just like the OEM one, that has the index slots off set 4 deg..
It has been said no difference is noted when installed on the 2001 and up. But I do not know of anyone that actually checked the stock ignition advance, for all years, by market (US, UK, JAP, ect) and noted what it was,, then again with a advance using anything from a dial back timing light to more advanced electronic devices .
Old 02-17-2014 | 02:00 PM
I have a 2005 with this advancer, certainly hasn't caused me any problems after approx 20,000ks
I know of others with late models that have it as well.
So I wonder if I now have 8 degrees advance what with a programmed 4 and a mechanical 4?, or does the mechanical override the programmed?
Who knows it goes O.K!
Old 02-18-2014 | 07:56 AM
thedeatons's Avatar
I didn't install one because I read a lot of older posts saying the 2001+ models already had the advance, so it was useless.
Instead I spent the $40 on having my flywheel lightened to Roger Ditchfield's spec. A local machinist did it for me. Quite the difference.
Does anyone have a rotor from a 2001, and a Factory Pro +4 advance rotor they could compare?
James
Old 02-18-2014 | 08:51 AM
pchrist's Avatar
Are there any out there for sale? I have a 98 not sure if it was ever done on it???
Seems like a cheap upgrade are the benefits worth it? Just a casual rider here!
Old 02-18-2014 | 11:07 AM
Factory Pro no longer makes them and email to them asking about another production run goes unanswered..
So used or NOS is the only source
CruxGNZ
08-10-2023 03:06 AM
Spaz'
05-15-2012 03:56 PM
VFR79
03-26-2009 09:32 PM
scottiemann
03-03-2007 07:48 AM
CNI Dawg
06-03-2006 05:58 PM
Quick Reply: WTB: Factory Pro +4 Ignition Advancer
