Wanted: Steering Stem
Why not just buy a lower and extract the stem. I think you can just push it out of the lower with a press. It's splined and there is no orientation so it's pretty simple. I might have a lower for a donor but I gotta check. Would this fit your purposes?
Nuhawk, don't know how I missed your response for the last 10 days.
That is exactly what i want, a lower with stem, press it out, take measurements, recreate.
Yes, if you have a donor, awesome? How much?
Thanks.
Erik
Thanks.
Erik
I might have one, let me check. Shoot me an e-mail so I don't forget.
If it helps, the steering stem is the same in many, many Honda models. The CBR600F2, F4, F4, 900RR, VFR750. VFR800, etc all have the same steering stem in the lower triple. That should help open up the possibilities.
OK I got one -actually I got two. I got no clue what part of a project this was but if you want it I can ship it. PM me your shipping details and I'll let you know. One of these might have been a deal from ebay that was from an f2 and was a total ripoff - I think the stem is the same but nothing else about the lower matches the Superhawk. The box on the other is labeled VTR Lower so I think that is the good one. Let me compare the parts so I get the right one to you.
Both of mine are wrapped in bubble pack with elec tape so I got to cut into them to see what is what. I think what I can see in the one is the lubriplate and the new bearings that I pressed on before realizing that this jerk had sent me an f2 lower instead of Superhawk lower. I'll cut into them tomorrow to make sure of this.
I'm not sure of the weld Greg but I will look -certainly if he's only looking for the stem he could use a small grinder to get rid of the weld. Will advise on that too but I don't remember it being there.
Yes, it's welded in place. I put the whole lower triple in my mill and cut the wel off so that I don't damage the steering stem It works pretty well.
Well, ****! I didn't remember it that way. I will check the f2 lower to make sure it's the same. Since the f2 lower clamp is not an issue here it's prob the best candidate for being cannibalized. I still think an angle grinder could address the weld after the lower is boken, cut away. I told you guys I would check today and I have been messing around all afternoon. The race is almost over so I will go open up that f2 and get some pix.
The plot thickens. I don't see how these fit together mostly because on both triples the lower seals are installed. You're just going to have to tear into it and find out.
The first picture is the comparison of the f2 triple in back with the Superhawk triple in front. You can see the fresh allballs on the sand blasted and carefully painted lower of the f2. After all was said and done we got our money back from this kid so this is all a wash for me. The extra bolts are just that - I have no clue. All the top nuts/clamp nuts are included. This is all shown in the second picture. I'll check for a shipping quote - I'm pretty sure this will fit into one of those priority boxes from the PO for $15.40 to any zip code in the US. I will advise.
On another, probably pointless note, is that white lithium grease on the All ***** bearing in the pic? I like using white lithium but decided to go with the Honda recommended molybdenum something something something grease on my all ***** swap. Any reason for the white lithium use? I guess I could search it.
There is a small ridge around the based where the stem meets the triple.
That was my original assumption but it is incorrect. You can stick your finger all the way up and not find a ridge or joint line.
Yeah, thirty years in a shop.
Absolutely, if he doesn't want it you can have but he has dibs so it's his call. If you are having dimension problems you might consider using the f2 triples with your new forks. You can see in the pix that they are just a little narrower.
The ridge he is referring to is the raised donut shaped feature on the END of the steering stem. That's a face weld that holds the stem to the lower triple clamp.
I understand that Jamie. But there is no apparent junction on the inside of the triple or the stem. Without pulling the seals there is no way to examine any signs of a weld on the exterior. What's also weird to me is that if you feel the metal up the walls of the triple and into the stem - the surface feels like a casting - maybe all one piece. Is it possible that the lower is machined from one casting and not an assembly of the clamp and the stem? It makes sense from a machining standpoint - what better opportunity for alignment. You shoot the triples and the axis to the stem out of one chunk of metal.
It's pretty clear that you aren't seeing how this goes together. The steering stem itself is a machined piece that is pressed into the clamp until it is flush at the bottom. A bead of weld is then placed around the perimeter as a face weld. Nothing extends into the ID. You won't feel any discontinuities on the inside because that entire surface is the machined stem. What you are feeling is the rough machined surfaces - just because it's machined does not mean it has to be smooth.
I'm probably not explaining this very well. It's been said that a picutre is worth a thousand words, and I just so happen to have my stock front end handy, so let's try:
All I need is the stem, either triple will work for me. These forks are far too massive for the F2 clamps. 46mm in diameter.
