954 Lower, SP1 Upper triple w\bearings
Old 04-09-2010 | 10:17 PM
As I have switched to a SP1 lower triple I have a fork swappers special.
The Lower is a 954 that has been set up to use in a SH. The steering stops have been modified to clear the fairing stay and also have been drilled for extended steering stops. Right now it is set up to be used with the radiators in the stock location. If they are relocated it is just a matter of unscrewing the stops and either readjusting or removing them.
Also included is a SP1 upper triple. It is not in the best shape but is not all that bad. The Honda emblem is missing also. It does have an ignition switch also (there is a broken off key in it and I haven't messed with it to see if i can get it out)
I will also include a set of tapered steering head bearings, so it's like one stop shopping.
I'm asking $215 for everything, including shipping in the lower 48 other areas might be different.
Old 04-10-2010 | 12:50 AM
ranchomice's Avatar
Why are you getting rid of this stuff? I thought you were using this combo.
Old 04-10-2010 | 08:20 AM
Your behind the times my friend.......
https://www.superhawkforum.com/forum...ad.php?t=22113
OCMD strikes again......
Old 04-10-2010 | 09:36 AM
956c's Avatar
956c is on a distinguished road
dude....I was wondering why some people do things the hard way to have inverted forks....why didn't you just used the complete upper and lower system from a 954...??? it is simple..no drilling just bolt on and RIDE...
Old 04-10-2010 | 09:49 AM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
The issue is usually finding a complete set at something approaching reasonable pricing. They're getting more and more rare, and thus the repeated scramble to find the right assemblage of parts to work it out. It's usually cheaper to assemble a set of parts that work, and it's almost always faster than waiting on a complete setup (wheel/brake rotors, forks, triples, clipons, fender) to come up on eBay or the like.
Old 04-10-2010 | 12:48 PM
Syclone's Avatar
Boosted
No, it's not quite bolt on and ride. A stock 929/954 lower triple has to be shaved down in order to turn past the fairing stay... just like the OP says...
Old 04-10-2010 | 02:32 PM
If you just take the 929/954 triple and bolt on and ride, you are severely limited on full lock (doesn't clear the fairing stay) and once you grind that of you pinch the top coolant hose on full lock to the extent of expensive repairs in a few rides, so you add/adjust the stops... All that is done here... If you want a full CBR triple tree, get the top one separate and the lower is truly bolt & ride...
Old 05-14-2010 | 01:14 PM
Old 05-24-2010 | 03:13 PM
Price drop...... let's try $165 shipped
Old 05-29-2010 | 04:14 PM
Old 07-05-2010 | 03:16 PM
Old 09-08-2010 | 01:59 PM
Sold
Old 09-08-2010 | 04:59 PM
Crashrat's Avatar
Drat. I was going to ping you after tomorrow -- when I get the $$$ for the clutch cover. Ah, that's just the luck.
xeris
03-18-2013 07:35 PM
8541Hawk
03-29-2010 10:46 AM
8541Hawk
03-27-2010 10:12 AM
KC-10ENG
03-09-2007 09:19 AM
selztoad
12-19-2006 08:56 PM
