Electrical issues...
Old Apr 25, 2010 | 12:07 AM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
I've had sporadic electrical "flukes" in the past that basically faded away and I left at that. I am now experiencing my turn signal indicators glowing at me intermittently, as well as my rad fan has stopped working and my speedo has stopped working, yet the chrono still ticks of miles. My low fuel light has only momentarily worked in the past... WTF... is any of this common? I am thinking my reg/rect is going, but I have not even bothered to check output voltage yet... that will be next.
Any ideas?
Old Apr 25, 2010 | 12:09 AM
LineArrayNut's Avatar
I could ride in
just from what i've read here, that sounds like classic rr failure symptoms...
Old Apr 25, 2010 | 12:49 AM
zubzero's Avatar
zubzero is on a distinguished road
Any ideas?
Whats a good oil for electric parts?? I have similar problems, i have found the reason for my bikes behavior. i Checked the wiring connectors behind the gauges and woila!! When i wigle the wiring connectors all gauges start to flicker...some will work and some will stop working...so the wiring connector is either broken or doesn´t connect properly. So i´m thinking of putting some perhaps WD-40 in there or does it make it worse or short shirquit the whole thing???
Old Apr 25, 2010 | 03:25 AM
Keep WD40 away from electrical stuff! It's a quick fix that makes it worse in the long run...
Get contact cleaner, nothing else, and then seal it with vaseline (avalable as spray on) But first have good look at the connector if it's broken you can see that... Otherwise clean all contacts, seal them and make sure all the small screws are tight (97-00 instrument)...
Old Apr 25, 2010 | 03:47 AM
zubzero's Avatar
will do that! Thanks Tweety... trying to find contact cleaner next time i go to carage...
Old Apr 25, 2010 | 11:13 AM
PUSHrod's Avatar
Contact cleaner then 'dielectric grease' on the connectors. Available at auto parts stores everywhere. Permatex makes some.
dakmatik
Jul 5, 2008 09:08 AM
Flying Dutchman
Mar 29, 2008 07:15 PM
99Hawkboy
Jan 15, 2007 07:12 AM
gambrjl
Sep 23, 2006 09:08 PM
98VTR
Jun 16, 2006 11:42 AM
