Stator replacement
Old Feb 26, 2010 | 09:12 PM
spladle160's Avatar
Stator replacement
I've decided that the annoying explosions in my heads are being set off by a faulty stator. I'm not really sure that this conclusion is correct but it's my current hypothesis and I'm gonna test it. I saw a cheep used one on ebay a few weeks ago but hadn't decided that the stator was the problem for sure and let someone else outbid me for 15 dollars. Anyways now I can't find one for cheap so I started trying to find other models that fit. none are an exact part number match. I did find an after market stator that said it fit and also fit the RC51. So now I'm thinking about getting one for an rc51.
Old Feb 26, 2010 | 10:23 PM
spladle160's Avatar
did some more digging and found this,
G14 Alternator
To Fit :- (Stator dia 115/54/25mm). VF700C V45 Magna 1984>. VF700F Interceptor 1984-85. VF700S V45 Sabre 1984-85. VF750C V45 Magna 1982-98. VF750F Interceptor 1983>. VF750S V45 Sabre 1982>. VF1000 Interceptor 1985>. VF1000f/F2 1984>. VF1000R 1984>. VF1100 1983>. VFR750F G/H 1988-89. *VFR750R-H 1988-93. VTR1000 Firestorm. VTR1000 SP1
Old Feb 27, 2010 | 05:51 AM
V-king's Avatar
insane
V-king is on a distinguished road
check for continuity between each wire terminal of the alternator side connector and ground.
there should not be continuity.
measure the resistance between the yellow wires - 0.2-0.5 ohm is ok.
start the engine and measure the voltage at the 3p terminal - should be the same to each wire.
Old Mar 3, 2010 | 12:18 PM
spladle160's Avatar
Well the alternator was the source for the spark, it has a big burnt spot where there is no coating on the windings, unfortunately I discovered the stator I bought doesn't fit. Doh! I bought one for a vfr800 wait that's not on the list.
dieschem
Jan 4, 2010 07:03 PM
Blurr
Apr 24, 2007 01:05 PM
Blurr
Apr 21, 2007 07:22 PM
igeorgei
Apr 17, 2007 08:07 PM
nineighthawk
Sep 14, 2006 10:01 PM
