cooling fan issues
Old Jan 23, 2010 | 08:01 AM
offroad_rider2008's Avatar
cooling fan issues
good day to everyone here, My first time here ty, ty, lol, newayz i just purchased an '02 superhawk 996 everything seems fine on it 'cept the cooling fan wont kick in temps hit 194 deg. the fuse seemed good still, ne ideas? ne help is appreciated
Old Jan 23, 2010 | 08:22 AM
It won't kick on till 215-220 degrees. If it gets that hot and still doesn't turn on then you have problems.
Old Jan 23, 2010 | 09:48 AM
Ground the temp sensor wire,,, if all is well the fan will kick in,, if not, check the fan power and ground wire..
Old Jan 23, 2010 | 10:42 AM
PUSHrod's Avatar
I wonder if the contact between the sensor and the wire plug end is good.
Same symptom with mine, fixed by cleaning to sensor male and wire female leads.
Old Apr 16, 2011 | 04:21 PM
JE55E's Avatar
JE55E is on a distinguished road
Cooling fan issues in Hawaii
Hi, I saw offroadrider2008's problems and answers. I have the same issue. Fan won't kick in. = (
All my fuses under the seat are good. (I don't know of any fuses elsewhere??) I checked the sensor at the switch, and cleaned the male and female leads.
I do not know how to "ground" a wire.
- Clueless in HI.
Old Apr 17, 2011 | 05:08 PM
RickB's Avatar
Turn on the ignition, take the wire off the temp sensor at the radiator, touch it to metal of the radiator - the fan should turn on as you have just provided the ground... Basically this is what the temp sensor does when it reaches its set temperature.
- Clueless in HI.
VTWINKID
Jun 1, 2011 04:19 PM
glrider
Jul 23, 2010 12:17 PM
Flying Dutchman
Apr 1, 2008 05:26 PM
SuperHawkins
Nov 1, 2007 06:41 AM
RickB
Sep 13, 2005 09:05 AM
