My Cafe Build
Old 12-01-2009, 11:10 AM
  #211
2nd mouse gets the cheese
Little_Horse's Avatar
ok, I understand what you mean. Well then hopefully it won't stick, and if it does will buy another cable. Thanks for following the build. I should have more for everyone in a little while.
Little_Horse is offline
Old 12-01-2009, 05:44 PM
  #212
I have those mirrors in black on my cafe. Well, I have one left. The other one fell off. The mounting system sucks ******** and didn't work well for me. I tightened the crap out of them too. The remaining one is modified to use the bar insert but rotates sometimes.
Hawkrider is offline
Old 12-01-2009, 06:35 PM
  #213
Yeah, I noticed the chinsy mounts. Since you for sure have had problems I may just go ahead and weld in threaded ends on the bar to fix. So did they rattle loose or could you never get them tight enough?
Old 12-01-2009, 08:32 PM
  #214
Never could get it tight enough. The mechanism inside spread to a point on the inside of the bar and it wiggled around no matter the torque on the bolt. If there were a flat surface to grip inside the bar it would be better.
Old 12-03-2009, 07:27 AM
  #215
Old 12-03-2009, 11:19 AM
  #216
Just a little teaser of the gauge I am working on. I will somehow imbed everything into the original housing, and have the tack needle work like stock.
Old 12-03-2009, 11:51 AM
  #217
Love the "Shift Already!" in the tach
lazn is offline
Old 12-03-2009, 02:24 PM
  #218
trinc's Avatar
since your printing your own gauge label, why not start the red line at the 12k mark ? thats where i'll have it
tim
trinc is offline
Old 12-04-2009, 07:19 AM
  #219
That would be fun to see...Lol. I don't even know if this thing has a limiter. Is that possible with only points firing it? Probably no limiter right?
Need to print a final face for the gauge install the face re attach the needle seal up the bottom buttons and then ready to roll. A one glance for all your info.
Old 12-04-2009, 07:34 AM
  #220
Yesterday the upholstery guy we use for the body shop stuff came by and talked to me about the seat. So long story short he is going to make the cover and add a little bit of foam to it in a few spots front and rear. He really wanted to shape the seat a lot more but I want to keep it flat so that when transitioning back and forth through turns you can easily move still. He is going to use a material that grips pretty well too. With as narrow as the seat is and how light the bike is there will be a lot of movement when riden hard. Pics to come when done.
Old 12-05-2009, 09:49 PM
  #221
So the gauge is complete. Aside from a small bit of sealing to be done, maybe some sanding and paint it looks really good and I think will function super.
Old 12-06-2009, 09:01 AM
  #222
The gauge is awesome. Nice job! My friend's dad has a worked mustang cobra and at the redline is says "mazel tov."
captainchaos is offline
Old 12-08-2009, 11:52 AM
  #223
Seat done!
Looks awesome, I am very happy with the results.
Old 12-08-2009, 01:54 PM
  #224
Looks great!
lazn is offline
Old 12-08-2009, 02:08 PM
  #225
trinc's Avatar
seams ?
did you plan these to flow with tank & cowl stripes ?
tim
trinc is offline
Old 12-08-2009, 02:33 PM
  #226
Originally Posted by trinc
seams ?
tim
yes I did, I wanted some style but not too much style. You don't like them?
Old 12-08-2009, 03:06 PM
  #227
That looks superb... That bike looks better each time you update this thread...
Dammit, I have enough projects, but you got me thinking again...
Tweety is offline
Old 12-08-2009, 03:35 PM
  #228
trinc's Avatar
it's just not often done, so good for keeping things different.
tim
trinc is offline
Old 12-08-2009, 03:42 PM
  #229
Tank and cowl go to the painter tomorrow!
Old 12-08-2009, 03:56 PM
  #230
+1
Old 12-08-2009, 04:37 PM
  #231
trinc's Avatar
did you decide on black or silver ?
tim
trinc is offline
Old 12-08-2009, 04:57 PM
  #232
pearl white with black stripe. Hopefully this will tie in all the black bits like the rims.
Old 12-09-2009, 04:36 AM
  #233
snipereps's Avatar
snipereps is on a distinguished road
Great job man.
I think your color choice will fit just perfect.
Are you planning any upgrades on brakes and suspension too?
snipereps is offline
Old 12-09-2009, 07:26 AM
  #234
Originally Posted by snipereps
Great job man.
Well as soon as the build is done and after I have ridden the bike some I will start to consider upgrades. Things like possibly fork emulators, electronic ignition, maybe a 650 cam since those work. Without changing the forks out, which I don't want to do, all I can do with the brakes is put a decent pad in there. Probably not a whole lot of options for upgrades since the tech is really old. Part of my goal with the bike was to keep it as vintage as possible. That is why for the most part everything that has been done either utilized the original part or was built from scratch. I have been looking for nice rear shocks if anyone might be able to help me with that quest. I want to find some with adjustable rebound and dampening not just pre load, but have been unsuccessful. I will probably put new springs in the forks too.
Old 12-09-2009, 10:54 AM
  #235
Arg!
On a serious note, now that I laid the whole vintage bit on you all I still am torn between carbon fiber or stainless for the can. Please help me decide.
Old 12-09-2009, 12:02 PM
  #236
Stainless Fiber for sure.. errm what?
If you want it to look "authentic" go stainless. If you don't care about that, go with whichever you like better. (I would recommend the 2nd route, whichever you like the look of better.. it is your bike, unless you are just planning to sell it.. then stay authentic)
lazn is offline
Old 12-09-2009, 01:22 PM
  #237
trinc's Avatar
i would think black... carbon or high temp black coating on SS or Al.
tim
the carbon can looks HUGE but that may just be the picture.
trinc is offline
Old 12-09-2009, 01:42 PM
  #238
tim
first pic is a joke second pic the carbon tube is 3.5 in diameter.
You don't think carbon is too "state of the art" for the bike?
Because I like the way the carbon looks too but that is my only concern.
Old 12-09-2009, 07:15 PM
  #239
Cigar Officianado
Stogey's Avatar
Stogey is on a distinguished road
Personally I like the snake skin look of the carbon fiber and I think it will tie into the black accents on the bike. Does it effect the overall sound by going carbon?
Stogey is offline
Old 12-09-2009, 07:50 PM
  #240
nope, well not much, that has more to do with the packing and size of the inner perforated tube.
Quick Reply: My Cafe Build
