Starting Problem. Please Help
Old Jun 27, 2009 | 04:46 PM
bcunning82's Avatar
bcunning82 is on a distinguished road
8-9 months ago I replaced the R/R with an R1 model and the bike was running fine. I let it sit since and am now trying to get it going again. I had no power to anything since the battery was run down. I have a charger on, and when I try to start it i get a loud buzzing from the starter silonid. Could the dead battery be causing this even though I have the charger on and my multi meter reads 12v? or is there another issue?
Old Jun 27, 2009 | 04:52 PM
Does your charger have a starting circuit (it'd probably be a switch you throw to start a vehicle with it) because if not, there is no way that your charger has enough amperage to start your bike.
Most chargers provide 1-2 amps of current.. you'd want something like 8 to 10 to start..
If your battery can recover by charging it overnight, you can try doing that and starting it in the morning.. but if you bike sat for a long time uncharged your battery may be dead.
Old Jun 27, 2009 | 05:25 PM
bcunning82's Avatar
Thanks,
I will give it a try in the morning. If i try to jump it with a car it should have enough amps? If that works then it is my battery. if not it is something else.
Old Jun 27, 2009 | 05:27 PM
Just be careful jumping from your car.. I would do it with your car not running. Or if you really want to have your car running, start it before you hook up to the bike and only idle the car.
Do NOT start your car with your bike connected.
https://www.superhawkforum.com/forum...ad.php?t=19173
Old Jun 27, 2009 | 05:28 PM
5150's Avatar
I don't need any Meds
5150 is on a distinguished road
Originally Posted by bcunning82
Thanks,
some one else just posted about doing that.. they fried a **** ton of items because the car was running. i would do a search about that before you try jumping it with the car.
Old Jun 27, 2009 | 05:30 PM
5150's Avatar
https://www.superhawkforum.com/forum...ke+running+car
look here before you do what you suggested. i could be wrong but i think you are asking the same thing
Old Jun 27, 2009 | 06:38 PM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
I think your battery is stuffed. It will show 12v when just sitting, but as soon as you try to start the bike, the internal resistance is dropping the volts waaay down, making the solenoid chatter. You can charge it until the cows come home but it won't help.
You could jump start the bike to go for a ride but getting home will be a problem. The battery will still be flat
drsmithy
Aug 28, 2013 07:57 AM
havoc7685
Apr 4, 2012 11:10 AM
mikayelstylee
May 7, 2011 12:31 AM
Kators
Nov 2, 2009 04:08 PM
mattvdsande
Mar 16, 2009 11:12 AM
