List of Bolt-On Front Brake Mods
Old 12-07-2007, 09:11 AM
  #61
supertwinSH's Avatar
supertwinSH is an unknown quantity at this point
Don't think so...I think they are radial mount. but don't quote me on that.
supertwinSH is offline
Old 12-07-2007, 09:24 AM
  #62
HELP Quickly
will an '07 600RR front brake calipers fit a '02 VTR?
Nope radial mount...
Tweety is offline
Old 12-07-2007, 09:39 AM
  #63
nnjhawk02's Avatar
U R correct
nnjhawk02 is offline
Old 12-07-2007, 10:54 AM
  #64
HELP Quickly
Aren't those radial mounted? which would mean no.........
8541Hawk is offline
Old 12-15-2007, 10:03 AM
  #65
ATGATT
newb007's Avatar
newb007 is on a distinguished road
Braided Brake lines with RC-51 Calipers
So I was looking at putting on some RC51 Calipers with braided brakes lines but not changing out the MC yet. Will the braided brake lines for the VTR work with the RC51 calipers? I figured they would but saw an auction on ebay for galfer lines with HH pads and it said specifically not for RC51. Is that just the pads or do the lines not fit VTR and RC51 the same?
I'm not going to buy the kit since i have fluid and the pads on the RC51 calipers are new. More concerned about the lines.
http://cgi.ebay.com/ebaymotors/HONDA...sid=p1638.m118
Thanks
newb007 is offline
Old 12-15-2007, 10:21 AM
  #66
I've never had a problem swapping lines on any Honda sportbikes except the lenth of the lines, which can vary. The pads for the RC51 are bigger than the SH. You can get the HH pads for @ 28 clams per pair so this may not be a bargiain(chaparralmotorsports.com). I just got a full f4i set of calipers with MC and steel lines for $100 (slightly used but still). Just some more info for the pile......peaceout
smokinjoe73 is offline
Old 12-15-2007, 10:25 AM
  #67
ATGATT
newb007's Avatar
That helps a LOT! I'm going to be bidding on some RC51 calipers shortly and if I get them I'll start looking around for braided lines next.
newb007 is offline
Old 12-29-2007, 05:35 PM
  #68
ATGATT
newb007's Avatar
Break upgrade
Well I found a set of CBR600RR brake calipers, MC, steel lines, Galfer HH pads for just under $100 including shipping on ebay. Put them on and had my first ride today with em. Very big improvement over stock and feel very strong. Thanks for all the info.
newb007 is offline
Old 01-11-2008, 07:30 AM
  #69
alive226's Avatar
I thought I would keep this question on this thread as it pertains to front brake mods. Does anyone know if SS brake lines from a 2003 600rr will fit 600F4i calipers and a 900rr MC? I have a chance to pick some up for a good price, but I wanted to make sure I can use them. Your help would be appreciated. Thanks
Rick
alive226 is offline
Old 01-11-2008, 07:48 AM
  #70
Well, the fittings is the same on almost all Hondas... The difference is mostly in the length of the line and if it's a 1-2 line or 2 all the way... also the angles at the ends and possibly mounting materials...
Basicly the best option all around is to buy for a VTR if you have a stock front end with upgraded calipers and M/C... but if you are getting used parts... It should work, but might need some creativity...
Tweety is offline
Old 01-11-2008, 08:41 AM
  #71
I just took my bike for a test ride after installing some F4i calipers..... WOW! What a difference... such great braking power with such little effort on the lever! Highly recommended!
inderocker is offline
Old 01-11-2008, 08:57 AM
  #72
*Waves fist in indierockers general direction*
Bah... I'm envious... Here it's snowing/raining and with patches of snow and ice... And I have now at the moment three ½ of a bike to combine... withdrawal is severe to say the least...
Tweety is offline
Old 01-11-2008, 11:16 AM
  #73
redman's Avatar
I almost always end up going to Storz, buying the fittings and making my own. That way you can route them however you want, put angled ends on and tuck them all away better than most stock SS replacements.
redman is offline
Old 01-11-2008, 11:17 AM
  #74
redman's Avatar
http://www.storzperf.com/jpgs/page18.html
redman is offline
Old 01-11-2008, 06:59 PM
  #75
alive226's Avatar
Thanks for the info guys.........I might check out that Storz.....
Inderocker......do you just have the F41 calipers and a stock MC or did you put on a different MC. I just bought a 900rr MC to go with my F4i calipers... Im hoping its a good combo.
alive226 is offline
Old 01-11-2008, 07:55 PM
  #76
Stock M/C with Galfer steel braided lines .... works wonderfully!
Old 02-07-2008, 03:35 AM
  #77
Kitch's Avatar
Kitch is on a distinguished road
OK, I'm looking into this just now.
I might well have some GSXR K1 six pots and can pick up a better MC (and lever if needed - most likely a 954/600rr one)
Can someone confirm for me what this means as far as brake lines go? I have steel lines on my standard VTR brakes currently, will I need new ones to fit either the GSXR caliper or MC or will the ones that are on it work fine?
Kitch is offline
Old 02-07-2008, 08:17 AM
  #78
they should work
Old 02-07-2008, 09:28 AM
  #79
redman's Avatar
Quick note to all of you considering front brake upgrades......DO IT!
I was just saved by my massive rotors, RC51 calipers and 600RRmc. Idiot slowing rapidly and turning left across oncoming lane to access vista point on other side without brake lights or turn signals...as I went to pass him. Had to use all my new brakes....locked the front etc. Made it but stock brakes would've had me eating pavement.
redman is offline
Old 02-07-2008, 11:12 AM
  #80
VTRumble's Avatar
The stock or replacement lines will bolt right on to the gsxr calipers.
Doug O.
VTRumble is offline
Old 02-24-2008, 11:22 PM
  #81
Finally finished my front brake mods. 01 RC51 MC (19mm), already had SS lines, and F4i calipers (34/32mm). Hand milled the calipers to clear the lower mount and epoxy coated the cuts. Everything went together well though cleaning the wheel (with kerosene) and then the rotors with red scotchbrite pads (first with detergent and a bit of ammonia and then with 91% isopropal alcohol) took the longer. Lever feel seemed a lot better than the RC51 MC and OEM VTR calipers, as the F41 calipers properly match the 19mm MC. Trouble is I don't know when I can road test everything. It will be interesting between my new bar mod (about 1.25" higher and 1.5" rearward than Helibars), my reshaping of a custom 1.5" taller Sargent saddle (this is the 3rd time I've wacked at it over the years) and the fully moded front brakes. The new bars and saddle are designed to mate with 1.25" lower pilot pegs for a true sport touring stance.
Still waiting for the Superbrace from the group buy!
skokievtr is offline
Old 02-25-2008, 08:41 AM
  #82
reaper's Avatar
I did the same upgrade early fall '07 but used the '01 RC51 calipers instead of the F4i and the slowing/stopping power for this combination on the SH is tremendous. I am pushing 290# with gear, not fat just a big guy, and the first ride was impressive.
Regarding the SB, you and Hotbrakes ordered the same black anodized brace and for some reason SB is having a hell of a time gettting these made. MFI spoke with SB about this matter and could not get a conclusive answer from SB. Hotbrakes cancelled his order. If you want to call MFI, here is there # 1-866-583-9600, anyone in Parts can assist you.
Good luck.
reaper is offline
Old 02-25-2008, 10:24 AM
  #83
Good luck.
Thanks man but I've been in recent contact. I DID NOT order a Black one, just the regular old Clear finish. Chris promised me something and I'm waiting a bit more to see if he comes through...
The F4i are identical to the 01 RC except they are Black. Hopefully it will be a nice change and hide brake dust, or the old Goldies are going back on my fast 98. I try things progessively, first the 01 RC MC, which increased pull and decreased sensitivity so the jury is still out until I can FINALLY ride! And its only the end of February.
Old 03-03-2008, 03:18 PM
  #84
XLSR-VTR1's Avatar
XLSR-VTR1 is on a distinguished road
woooo woooo my head is spinning. brake overload! Thanks for all the great info. Im in need of this mod and now just need to sift thru all the options. Id like to reuse my aftermarket levers and my ss lines. Any of these mc's fit this with a remote reservoir?
XLSR-VTR1 is offline
Old 03-03-2008, 07:00 PM
  #85
Certain levers fit certain MC, check the thread(s), its been covered. Most lines will fit but the angle of the dangle on the cal varies. Just remember not all cals are true bolt on, like the RC51 and F4i which need a bit of milling to clear the OE VTR lower cal mount bracket.
Old 03-04-2008, 10:43 AM
  #86
XLSR-VTR1's Avatar
Thanks. Anyone have pics of F4i or RC Caliper after being trimmed to fit? There are alot of options it looks like and may come down to availablitly. superbling pointed me to an F4i setup I may look into.
Old 03-04-2008, 06:09 PM
  #87
BenjaminVFR750's Avatar
BenjaminVFR750 is on a distinguished road
Thanks guy for all the awesome advice XLSR-VRT1 I am in your shoes to much goodness to choose! I will be posting up some pics of my upcoming mod soon enough before my track day here in about two weeks. Hopefully all will go well!!
Hey XLSR My bro lives in ballard and rides a VFR you got alot of guys you ride with up there?
BenjaminVFR750 is offline
Old 03-04-2008, 06:58 PM
  #88
I don't have photo's of the trimmed area on the calipers, I do have mounted shots though. I included stock caliper photo's for size reference. The F4i's/RC51 Calipers are a lot more potent that they look!
Old 03-04-2008, 08:36 PM
  #89
Not my milled pics cuz I also forgot to shoot my black F4i calis but these gold RC51 are milled the same. 00 & 01 RC51 calis are the same as all the F4i but after the reduced the RC51 pistons a bit. Note very carfully where the cut is and how deep, its not centered and they are opposite hand left-right. Do not cut too deep and touch up with 2-part epoxy paint the bare aluminum. The installed pic is my work.
Attached Thumbnails List of Bolt-On Front Brake Mods-milled_rc_calipers.jpg   List of Bolt-On Front Brake Mods-milled_rc_calipers_2.jpg   List of Bolt-On Front Brake Mods-vtr-w-f4i-caliper-r-l.jpg
Old 03-04-2008, 08:42 PM
  #90
Thumper's Avatar
I installed the six pot GSXR calipers and have an 07 GSXR1000 Radial Front Master cylinder and lever assy. on the way from Ebay.
I am excited about trying the Radial Master cylinder with its improved plunger location.
I most likely will need to buy new SS lines and sell my existing SS lines as the Radial MC has different line connection angle over the older traditional MC's
Thumper is offline
Quick Reply: List of Bolt-On Front Brake Mods
